Installing 12v power outlet - Kawasaki ZX-10R.net
post #1 of 29 Old 06-22-2010, 08:06 PM Thread Starter
Does not drive into smoke
El Zilcho's Avatar
I have a cig lighter socket that I want to install somewhere near the front of the bike. I plan to use it for my GPS (since the battery won't last long enough to keep it on on long rides).
What is the best place to hook up the power wires to? My bike is 2004.
El Zilcho is offline
post #2 of 29 Old 06-22-2010, 08:11 PM
dirt ninja's Avatar
Images: 9
I ran a power wire up from the battery to the speedo that powers my radar detector and cig plug that i mounted to my fairing stay with a zip tie.
Marchesini Magnesiums,Nassert beet,kawi cam,.45 headgasket,DJ PC/Ig.M/QS,velocity stacks,bmc race,gipro,sato rearsets,helibars,throttlemeisters,pazzo shorties,speedohealer,520 renthal sprockets,penske 8393 double clicker,traxxion dynamic springs,scotts stabilizer,lsl frame sliders,cox radiator guard,powerbronze hugger,puig DB,solo seat cover,Valentine1,dual low beam projectors,55w.hids, brembo superbike rotors,Goodridge superbike lines,nissin calipers and rizoma mirrors,mda123 battery.
dirt ninja is offline
post #3 of 29 Old 06-22-2010, 08:20 PM Thread Starter
El Zilcho's Avatar
You didn't put it through a relay?
I was wondering if there is a convenient spot where I can just hook up the cables without needing to install another relay. I expect the current drawn from the socket to be minimal, at least for the GPS, so I can live with a temporary solution for a little while.
post #4 of 29 Old 06-22-2010, 08:23 PM
dirt ninja's Avatar
Images: 9
No relay here... The outlet draws no power as long as nothing is plugged in.
post #5 of 29 Old 06-22-2010, 08:25 PM Thread Starter
El Zilcho's Avatar
Lol.. I suppose you have a point here.. :)
post #6 of 29 Old 06-22-2010, 08:37 PM
dirt ninja's Avatar
Images: 9
Your good to go.. how about a little rep. ;)
post #7 of 29 Old 06-22-2010, 08:44 PM Thread Starter
El Zilcho's Avatar
I hope my rep power is > 0... :D
post #8 of 29 Old 06-22-2010, 08:58 PM
dirt ninja's Avatar
Images: 9
Thats a big negative haus!
Thanks for the trying!
post #9 of 29 Old 06-23-2010, 01:09 AM
pmason718's Avatar
Send a message via AIM to pmason718
where can I get a cig plug from to install on my bike Autozone?
pmason718 is offline
post #10 of 29 Old 06-23-2010, 01:27 AM
NinjeR's Avatar
walmart, autozone, advance etc etc...just buy a simple cig outlet and cut the wires then splice into the power wires you need.
NinjeR is offline
Anyone hook up a power outlet on their 10? kawlreaper The ZX-10R 5 02-24-2009 07:30 AM
Power outlet installation??? borntoride719 The ZX-10R 6 07-01-2008 06:12 PM
installing power commander '05 zx10r... disconnect fuel line from bottom of tank? CaFFeineSouLja Performance and Tech 13 02-14-2007 03:01 AM
Made a 12v accessory supply for my ZX10 06450F Performance and Tech 6 12-17-2006 05:55 PM
Installing power commander gixxerich The ZX-10R 4 05-30-2004 05:27 PM
