Installed shift light - Kawasaki ZX-10R.net
post #1 of 7 Old 08-10-2008, 07:41 PM Thread Starter
kansasboy's Avatar
Did some searching but couldn't find much on this.
I took a standard shift light off a sunpro tach and installed it on my bike. You have to dissassemble you speedo and find your stock shift light led. I pulled it out and replaced it with the two wires going to my aftermarket shift light. The led's run around 3-3.5 V instead on this bike instead of 12V so I went to radio shack and got a 10mm clear led. Swapped the standard bulb out with the led, then I mounted it and have a cheap shift light you can see.
ID:	75035   Click image for larger version
06 ZX10R
kansasboy is offline
post #2 of 7 Old 08-10-2008, 08:44 PM
Ex Postwhore
9520G's Avatar
Send a message via MSN to 9520G
That actually came out very nice.Rep sent.
"Never trade the thrill of living, for the security of existence"
9520G is offline
post #3 of 7 Old 08-10-2008, 11:26 PM
tigersurvival's Avatar
Send a message via AIM to tigersurvival Send a message via MSN to tigersurvival Send a message via Yahoo to tigersurvival
Heh, why did you "white out" the time?
Other than that! Nice touch man.
tigersurvival is offline
post #4 of 7 Old 08-11-2008, 02:01 AM
La Flama Blanca
9R to 10R's Avatar
Images: 102
Looks cool, let me make sure I got this right, you switched out the bulb in the sun-pro light with another bulb from radio shack? T
To get the signal wire to power the sun-pro tach you broke open the stock gauges and tapped directly into the stock LED wires?
9R to 10R is offline
post #5 of 7 Old 08-11-2008, 02:49 AM
Sebastian1000's Avatar
Not hating but you replaced a shift light with a shift light? Is it really that much easier to see? Looks good though.
1976 250 Elsinore Sold
1997 600R Sold
1976 KZ 900 Sold
2003 1500 Meanstreak Sold
2006 DL 650 Sold
2002 919 Hornet Sold
2004 ZX-10R
Sebastian1000 is offline
post #6 of 7 Old 08-11-2008, 08:59 AM Thread Starter
kansasboy's Avatar
I didn't white out the time, must be the glare when I took the pic.
Yeah, took apart the speedo and removed the led off the board and ran my wires off the board to the shift light.
I had trouble seing the stock shift light this one is Much brighter and bigger. makes it easier to hit my shifts at the same point when I drag race it.
Thanks for the comments.
06 ZX10R
post #7 of 7 Old 08-12-2008, 12:52 AM
Oh! I see the glare now, my bad.
shift light wpbzx-10 Performance and Tech 7 02-18-2008 07:33 AM
Better shift light?? sxi The ZX-10R 27 01-17-2007 07:24 AM
How do you set the shift light? hale The ZX-10R 13 11-02-2005 04:42 PM
Shift Light, anybody try this one? BIKEMIKE The ZX-10R 13 04-17-2005 08:23 PM
Shift light Bobster The ZX-10R 12 04-08-2005 12:54 PM
