INstalled Akra full system...TQ value discrepency - Kawasaki ZX-10R.net
post #1 of 8 Old 01-11-2010, 09:27 PM Thread Starter
Send a message via AIM to wickedsprint
So when installing the Akra system I noticed that they include a spacer that goes behind the bolt that holds the radiator bracket to the front of the engine case. Akra claims 106 in/lbs and after double checking with the service manual on page 4-16..it seems the actual TQ is 62 in/lbs. Going to re install at 62 in/lbs..but hopefully did not strip threads into the friggin engine cases because I blindly trusted the installation instructions..man would I feel like a jerk. Any idea why they might think (guess?) 106 in/lbs?
wickedsprint is offline
post #2 of 8 Old 01-11-2010, 09:29 PM
nickalltogether's Avatar
People torque those? I don't think the factory even torques those? If the bolt didn't break you're fine.
2012 Kawasaki ZX-6R-Black
Clear Alternatives Tail Light
2005 Honda F4i-Red
Commuter stuff
2003 Yamaha Zuma-Fairy Silver
TPT 70cc Kit, Leo Vince ZX Exhaust, Malossi Delta Clutch, Scott's Damper Sticker
nickalltogether is offline
post #3 of 8 Old 01-11-2010, 09:36 PM Thread Starter
hopefully..debating if I wanna yank the exhaust back out to prop tq the bugger.
post #4 of 8 Old 01-11-2010, 09:42 PM
I wouldn't. I typically torque something like that GNT (good n' tight)
2005 Honda F4i-Red
Commuter stuff
post #5 of 8 Old 01-11-2010, 09:48 PM Thread Starter
The only possible reason I could see them using a higher TQ value is because they showed it being done with a universal joint...which affects the TQ. I hate threading shit into aluminum haha.
post #6 of 8 Old 01-11-2010, 10:12 PM
5-F Dawg's Avatar
sorry if i came in late, but what model of bike is this and can you please post some pics!
BOOM!!! SHAKE AND BAKE
5-F Dawg is offline
post #7 of 8 Old 01-13-2010, 05:47 PM
phastone's Avatar
...it's just a radiator support and we're only talkin' about 4 ft-lbs difference.
Are you one of the people that torque the filter and drain plug to exact specs also?
phastone is offline
post #8 of 8 Old 01-13-2010, 06:16 PM Thread Starter
Sometimes...I have absolutely zero feel for bolts into aluminum...and since this is into the engine cases..I am being super anal.
Anyhow...I got an update from Akra. They maintain that 106 in/lbs is the standard for a 6mm bolt..and Kawi says 62 in the manual.
So...I found a lockwasher and a thin washer that have roughly the same thickness of the washer they provided...it was a weird shape and got deformed when tightened.
I then re-installed with a it of threadlock to a skosh over the 62 in/lb setting.
The only reason the washer is even required is due to the new headers coming closer to the radiator over the stockers.
On another note..the bike sounds absolutely amazing..and it feels like the flat spot around 6k is gone. Holy cow it's loud though.
04/05 full akra system fbmbks Wanted: Buy or Trade 2 10-01-2007 07:14 AM
Full System Installed! Not Akra's 06blackpearl Pictures and Videos 32 07-27-2007 09:56 PM
akra bolt ons vs akra full system, dyno numbers ? livharder Performance and Tech 3 07-02-2007 02:58 AM
akra full system biljeek The ZX-10R 3 06-29-2006 12:24 PM
for those who have installed an Akra full Eric_The_Jew Performance and Tech 5 02-05-2006 10:47 PM
