Gen 4: 2011-2015 Installation of Smog Block Off Plates - WHO HAS DONE IT?? - Kawasaki ZX-10R.net
post #1 of 44 Old 05-08-2012, 12:02 PM Thread Starter
I searched the site to see who has installed these on a Gen 4 2011/2012 model zx10r and could not find the write up anywhere if anyone has done it already. It is very tight in under the air box and they have a plastic rubber covering everything under there.
Who has done this and what do u do with the sensor which goes into the unit which is being removed? Will it through a FI light if u leave it alone? I know on the 07/08 ZX6R someone took a staple and made a connection from the two pins to stop the FI light.
Let me know if anyone has done this and what your results have been.
Thank you
mdc160 is offline
post #2 of 44 Old 05-08-2012, 12:11 PM
GreenWeenie's Avatar
Leave the valve in the harness, or you will get an FI light. (Or have your ECU flashed to ignore it)
You "could" just rip out the plastic shield.......
I just plumbed them together with a piece of hose.
No results....only clears up the a/f for dyno tuning.
GreenWeenie is offline
post #3 of 44 Old 05-08-2012, 02:00 PM
GSP
GSP's Avatar
Same here.
GSP is offline
post #4 of 44 Old 05-08-2012, 02:32 PM
nakedinseattle's Avatar
i just capped them off and left the thing plugged in. same effect basically
nakedinseattle is offline
post #5 of 44 Old 05-08-2012, 02:38 PM
Volzx10r's Avatar
Ivan's block off kit includes a mod to defeat the Fi light. Take the entire KLEEN air actuator out. Every gram helps!
Volzx10r is offline
post #6 of 44 Old 05-08-2012, 04:28 PM
tacp_daddy's Avatar
A very good how to write up is here: about half way down the page.
http://www.untamedvelocity.com/2011%...ke%20build.htm
tacp_daddy is offline
post #7 of 44 Old 05-08-2012, 06:43 PM
I was looking for this, thx
BronxRR is offline
post #8 of 44 Old 05-08-2012, 08:12 PM Thread Starter
Thx guys this helps out tremendous. Appreciate the feedback.
mdc160 is offline
post #9 of 44 Old 05-09-2012, 12:07 AM
pull the tank, pull the airbox, pull the plastic cover off teh front, the system is up front, 3 hoses, two screws on top of each place, piece of cake
post #10 of 44 Old 05-13-2012, 05:54 PM
ramoszx12r's Avatar
Do you have pic. of it.
ramoszx12r is offline
Gen 3: Smog Block-Off Plates eaharris Wanted: Buy or Trade 5 03-02-2012 11:49 AM
smog block off plates jryanfallon The ZX-10R 7 05-13-2011 02:52 PM
Smog Block Off Plates Antoniozx10r The ZX-10R 6 04-21-2011 10:43 AM
Smog Block Off Plates? speedking1000 The ZX-10R 8 10-15-2010 11:02 AM
got the smog block off plates garcia2389 The ZX-10R 9 08-09-2010 10:34 PM
