Injectors not working Gen 2 - Kawasaki ZX-10R.net
post #1 of 5 Old 05-25-2012, 01:02 AM Thread Starter
I replaced the engine from my 06 with an 07 Zx10. I got everything back together and my injectors aren't sending fuel. I replaced the injectors and it turned on. I put everything back together then it didn't fire up again.
I pulled the injector rail out of the throttle body and pointed then up. hooked up the tank to if it would spray fuel and non of the injectors are not working again
The tank primes, but nothing comes out of the injectors. I have pulled every connection apart and spray the electronic cleaner.
I cannot find where the bad connection is. I have removed my power commander, but still have my tre plugged in. Checked the grounds for the battery and chases. I saw a thread about a blue connector, that goes bad but I think it was only on the first gen because I could not locate it. It is in neutral when I try to crank it to rule out kickstand and clutch sensors.
calie0 is offline
post #2 of 5 Old 05-25-2012, 04:29 AM
Gen2 Ripper
neverendingmods's Avatar
The connector that goes bad is factory wrapped in black electrical tape and can be hard to find. Member hellsrazor is the one that made the thread so search his posts or PM him.
Good luck man.
neverendingmods is offline
post #3 of 5 Old 05-25-2012, 12:22 PM
SpazOnaZX's Avatar
...I'd start around the crank and cam sensors.
No, that's a lie. I'd open the service manual and do troubleshooting from that first. Everything you need to know about the bike is in there.
SpazOnaZX is offline
post #4 of 5 Old 05-26-2012, 01:32 PM Thread Starter
Checked cam and crank sensors. I cleaned all connectors.. Then all of a sudden had power to the injectors. I hooked the tank back up and it started up. I put everything back together, air box fairings, seats, and it wouldn't crank up again.. Same issue.. No power to injectors..
calie0 is offline
post #5 of 5 Old 05-26-2012, 02:51 PM
gazx10's Avatar
commom wire to injectors, believe its white and red, is power, u can tap fuel pump as scource of power if thats your problem. try a jumper from pump to the single wire that splits off to power injectors. kickstand can also disable injectors.
gazx10 is offline
Tags
injector
8 injectors on 06/07? Quantrill The ZX-10R 2 10-09-2011 11:26 AM
injectors redline659 Performance and Tech 9 06-02-2008 10:00 AM
zx-10R injectors KIRK_ADAMS Wanted: Buy or Trade 2 05-08-2008 09:09 PM
injectors?? zx-sik-r Performance and Tech 11 04-29-2008 12:57 PM
injectors sweetride10r Wanted: Buy or Trade 4 11-26-2007 09:30 AM
