Ignition Module - Tested finally !! - Kawasaki ZX-10R.net
post #1 of 71 Old 11-14-2005, 07:04 AM Thread Starter
ivansperformanceproducts.com
Ivan is offline
post #2 of 71 Old 11-14-2005, 09:51 AM
bluebyyouz's Avatar
Originally Posted by Ivan
Well.... it's a year later and they finally released the ignition module.
This is the best way to advance the timing on the ZX10.
Timing is adjustble at any throttle position and any rpm in 250 rpm increments.
For bikes that are using the TRE.... The light ping at very low rpm can be eliminated.
More power at full throttle throughout the rpm range (2-4 hp)
More throttle response at part throttle.....
As if you thought that the TRE would give the max.
This product is not a substitute for the TRE and it does not do the same thing.
They still need to be used together for you to get the best result
After the new timing map is installed, the bike will run cooler as well......noticeably.
The only thing about this product is that .....for it to be installed on the bike, the PC3 must first be programmed to accept it.
This is ok for guys that are familiar with software adjustments and such.
(there is a CD that comes with it)
But, for the guys that like everything pre-programmed, both units must be programmed together.....
It is best to purchase them together so they can be programmed together
This is because the PC3 controls the Ignition module, And the Ignition map is stored in the PC3.
So, you can do it yourselves, or if you would like to... (a pain in the butt)...
Ship your PC3 to us and I'll do the programming (provided that you buy the Ignition Module from us)
I have pre-programmed a bunch already for the GSXR and ZX636 and a few for the ZX10R
If you want your ZX10 to be the very best that it can be.... this product is a must have.
Ivan :)
Does the module plug into the USB port or the expansion port on the PC3? If it plugs into the expansion port will I have do away with my quickshifter since it plugs into that port?
bluebyyouz is offline
post #3 of 71 Old 11-14-2005, 04:35 PM
LordBadly's Avatar
Images: 13
Cool!! Are they readily available? or is there a wait. I may have to pull the PC 3 off and ship it too ya over the winter and get one!! thanks for the info Ivan!!
LordBadly is offline
post #4 of 71 Old 11-14-2005, 04:48 PM
Pressley10r's Avatar
Send a message via AIM to Pressley10r
got any before/after dyno sheets?
BIKES ARE THE FASTEST
Pressley10r is offline
post #5 of 71 Old 11-14-2005, 04:55 PM
Post Whore
1killer1liter's Avatar
Images: 11
Ivan already stated that it made more hp. The graph may not be available just yet.
I live my life a quarter-pounder at a time. And for those 500 calories or more, im free. I need FRIESSSS! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didnt blow a seam on your nugget box.
1killer1liter is offline
post #6 of 71 Old 11-14-2005, 06:56 PM
MIA Post Whore
miykl's Avatar
Ivan- Any better/how much better than the static timing advance (done per your instructions)? Any rpm ranges retarded?
2011 Ninja 1K street
2004 636 track
miykl is offline
post #7 of 71 Old 11-14-2005, 07:14 PM Thread Starter
Ivan is offline
post #8 of 71 Old 11-15-2005, 12:50 AM
phastone's Avatar
Thanks, Ivan. Once again coming through with real info we can use.
phastone is offline
post #9 of 71 Old 11-15-2005, 02:08 AM
Rspec99's Avatar
Images: 11
How about the rev extend function. The stock 10R doesnt even get to a "real" 13k rpm. Is it safe to do so?
Does it allow u to modify ignition advance or retard by gear and/or throttle %?
Also, how much is it?
Rspec99 is offline
post #10 of 71 Old 11-15-2005, 03:46 AM
WTtoolman's Avatar
Hey Ivan! My bike always runs hot as a bastard! How much cooler does the ignition module make the zx10r run? Does the module affect gas milage? Oh yeah, what does it cost?
WTtoolman is offline
dynojet ignition module den Performance and Tech 10 08-17-2005 08:39 PM
Dynojet Ignition module EMAIL response jrsjkd The ZX-10R 10 05-20-2005 05:56 PM
Ignition Advancer BNninja Performance and Tech 10 04-30-2005 06:38 AM
Dynojet Ignition Advancer COMING Spring moose The ZX-10R 18 02-23-2005 07:13 AM
Ignition Advancer cali10rider Performance and Tech 21 11-06-2004 02:08 PM
