Ignition Module Map - Kawasaki ZX-10R.net
post #1 of 2 Old 08-17-2007, 09:42 PM Thread Starter
Rizzo's Avatar
Ignition Module Map
Hey guys,
Can someone confirm where the map information is stored for the Ignition Module, if its in the the Ignition module or on the PC3. I have just recently picked one up and will be installing it shorltly just wanted to make sure it will go in with a zero map and not a map that was already put on it as I wont be getting it tuned for another week. I was thinking that the maps would be saved onto the PC3 and not the ignition module so I figure I should be safe until the tune. I dont have the ability to check it on my computer. If anyone is the wiser please enlighten me.
I bought the Module second hand, thats why im curious as to what map would be on it.
Thanks
Rhys
Rizzo is offline
post #2 of 2 Old 08-17-2007, 10:17 PM
Speed Freak
garth285's Avatar
map will be only in the power commander map along with the fuel map. will be at a zero map but you can easily check it when you hook up the power commander to your computer.
garth285 is offline
Ignition Module PROBLEM!?!? Suzuk1ki11a Performance and Tech 10 03-22-2007 05:45 PM
TRE and Ignition Module N.H.10r Performance and Tech 8 02-15-2007 05:46 PM
Ignition module & tre KlevaOne Performance and Tech 2 08-07-2006 12:57 PM
Ignition Module? Gregg627 Performance and Tech 11 07-02-2006 06:13 PM
Ignition Module zixxer Performance and Tech 3 02-07-2006 01:12 PM
