Ignition Advancer - Kawasaki ZX-10R.net
post #1 of 22 Old 11-03-2004, 07:38 PM Thread Starter
Thumbs up Ignition Advancer
Ever since i started my performance mods i have been looking for adjustable ignition advancer.So far I have the sato slip w/pcusb,Gilles rearsets,factory pro v-stacks,and shift star.I'am waiting to throw on my stacks and t.r.e. but want to ad ignition advancer so if anyone knows anything fill me in.
cali10rider is offline
post #2 of 22 Old 11-03-2004, 09:52 PM
Supercharged Mod
The right way to do this, IF you want to do this, is to re-map the ECU. A plain old-fashioned advancer changes the timing by a fixed amount throughout the speed/load range, which isn't really the right solution.
If you read the documentation on the PowerCommander website, a version of the PowerCommander with adjustable ignition mapping is not available because fiddling with the ignition timing doesn't do much on modern bikes that are quite optimized right off the showroom floor. (I tend to suspect another reason it's not available because it would be too easy for people to adjust things that they shouldn't be adjusting, and blow something apart.)
This engine has a very high compression ratio in stock form. There is a big risk of detonation if the ignition timing is advanced too far. If the ignition timing is already at the best-torque point, any change to the ignition timing will result in a LOSS of power. If the ignition timing is detonation-limited, advancing it to best torque will require the use of higher-octane fuel ... and this engine already wants premium. If the ignition timing is retarded for emissions or noise reasons, this is only likely to be in the low-speed part-load range (the EPA test procedure is only under those conditions) and not at the full-load range, so no effect on power.
Methinks for normal street use, don't mess with it except maybe for the TRE. I have messed around on other bikes with ignition timing, and I really only found it useful on a non-stock carbureted bike to cover up a mid-range rich spot. The right solution would be to get the air/fuel ratio right ... with carbs, only SO much can be done; with EFI and your Power Commander, you can get it a lot closer. It's better to fix the problem at the source (wrong air/fuel ratio causing slow combustion) than to cover it up by advancing the timing ...
You could always buy the kit Kawasaki ECU for US$1700 and fiddle to your heart's content, if you insist upon it ... If you want to run high-octane "race fuel", there could be power to be found; with pump gas, I doubt there's much if you want to keep some safety margin against detonation ...
I messed around with bikes in my younger days, and I still mess with my race bike because it matters. For street bikes, I've learned why things are the way they are over the years, and I mostly leave them stock and just ride them ...
GoFaster is offline
post #3 of 22 Old 11-04-2004, 06:57 AM
Ivan is offline
post #4 of 22 Old 11-04-2004, 10:59 AM
Supercharged Mod
That's the easy way to do it. Cost: $0, and reversible if you don't like it.
I wonder how much margin there is against detonation ... ? ? ? Will depend on the octane of the fuel you are using. Also, it will be temperature dependent ... same setting that gives no detonation with outside temperature 10 degrees C may have detonation if you are stuck in traffic with outside temperature 35 degrees C and you can't get premium fuel ...
I normally stay on the conservative side with internet recommendations, in the interest of not having people say "But you said it was OK, I tried it and melted a piston!"
GoFaster is offline
post #5 of 22 Old 11-04-2004, 11:37 AM
Big Daddy's Avatar
Images: 38
Originally Posted by Ivan
I slotted the pick-up coil and added appx. 4 degrees of advance......The bike picked up 3 hp at peak with gains starting at 6000 rpm.
I have no detonation problems.
Ivan
Ivan
What were your findings below 6k ??
Big Daddy is offline
post #6 of 22 Old 11-04-2004, 12:23 PM
calirider
let us know how those velocity stacks turn out. Also, I thought I saw that factory pro is doing R&D on an ignotion advancer for the 10.
BNninja is offline
post #7 of 22 Old 11-05-2004, 06:45 AM
Ivan is offline
post #8 of 22 Old 11-05-2004, 12:25 PM
Ivan-I'm curious to see dynos as well, specifically in the mid. Biggest problem I'm having with my race bike is wanting it to hit softer in the mid. It just wants to light the tire off when you get back in the gas. Any suggestions?
Top Shelf is offline
post #9 of 22 Old 11-05-2004, 12:32 PM
Big Daddy's Avatar
Images: 38
put a throttle limiter on it and set it @ 1/3
post #10 of 22 Old 11-05-2004, 12:37 PM
Maybe then you could keep up!!!! You have any days coming up BD?
Ignition Advance Rotor Evil 10 The ZX-10R 10 05-08-2004 02:39 PM
