ignition advance - Kawasaki ZX-10R.net
post #1 of 22 Old 06-02-2007, 09:54 PM Thread Starter
redline659's Avatar
ignition advance
06 zx-10, how much advance are you getting away with on 93 pump gas, and how much does the bike seem to like.???????????
redline659 is offline
post #2 of 22 Old 06-02-2007, 10:09 PM
FAF
Rent this space
Thats a good question, I dont have the answer but I would like to know.
FAF is offline
post #3 of 22 Old 06-03-2007, 04:55 PM
Speed Freak
garth285's Avatar
you basically need to advance it just enough before detonation and loss of horse power, with different mods you will need different maps and adding timing is a custom type of thing. best bet is to get on a dyno.
garth285 is offline
post #4 of 22 Old 06-03-2007, 09:11 PM
FAF
Rent this space
Didnt answer the question Garth dude, time to get the strobe out I guess??
FAF is offline
post #5 of 22 Old 06-03-2007, 09:30 PM
Speed Freak
garth285's Avatar
I have 10 degrees advance on mine if that helps you at all but im no stock motor.
garth285 is offline
post #6 of 22 Old 06-03-2007, 09:39 PM Thread Starter
redline659's Avatar
hahahah, not by any means, is it all ignition module, if so then thats as far as she will go until you crack open the case and advance a little from there hahahah
post #7 of 22 Old 06-03-2007, 09:45 PM
Speed Freak
garth285's Avatar
huh? lol
kinda lost me but yeah thats all from the ignition module.
garth285 is offline
post #8 of 22 Old 06-04-2007, 10:21 AM
FAF
Rent this space
Any idea what stock maximum advance is ?
FAF is offline
post #9 of 22 Old 06-04-2007, 10:29 AM Thread Starter
redline659's Avatar
it really depends on what fuel you are going to run. If you run good high octane race fuel say good ole c12, you can map in 10 degrees, which is as high as the ignition module will let you go. pump gas we have run 6 degrees with no issues, and you could prolly get away with 8 or even 10 but no need to push it that much, unless the check book is weighing your pocket down. The motors are really tamed down as far as that goes. But it all is relative how how good your exhaust and intake flows. We have thrown ignition advance at a bike with very very little increase in power.
post #10 of 22 Old 06-04-2007, 10:31 AM
FAF
Rent this space
So nobody has a clue what stock ignition advance is then ??
FAF is offline
Dyno jet ignition advance. otto Parts, Gear and Accessories 7 07-22-2006 05:38 AM
Dyno jet ignition advance. otto Performance and Tech 3 07-18-2006 07:45 PM
factory pro Ignition Advance Rotor? avdigigeek Performance and Tech 4 06-07-2006 04:24 PM
Ignition Advance BNninja Performance and Tech 11 02-16-2005 09:04 AM
Ignition Advance Rotor Evil 10 The ZX-10R 10 05-08-2004 01:39 PM
