If your valves are out of adjustment, what are the symtoms?? - Kawasaki ZX-10R.net
post #1 of 10 Old 06-22-2012, 10:38 AM Thread Starter
Heavyweight's Avatar
A buddy of mines bike is really hard to start, symtom of valves out of adjustment??
Livin The Dream
Heavyweight is offline
post #2 of 10 Old 06-22-2012, 10:49 AM
ZXRANDY's Avatar
It can be. That or a problem with the starter. What does the bike do when you try to start it and is the performance sub par? And how many miles are on it.
ZXRANDY is offline
post #3 of 10 Old 06-22-2012, 10:56 AM Thread Starter
its an r1 with 33000 miles, it sometimes feels as if the starter isnt strong enough to turn it over and turns over alot before starting, and he says he feels a loss of power throughout the rpm range
Livin The Dream
post #4 of 10 Old 06-22-2012, 11:25 AM
SkyDork's Avatar
its an r1
There's the problem.
Seriously, if the starter isn't turning over very strong, it's probably a battery or starter issue. It could be the valves, but more than likely that would have other symptoms like a rough running engine, poor performance, etc. and not just limited to starting it. If the battery where weak, it may not be providing enough power to the fuel pump to get the fuel pressure up enough. I'd look at the battery/charging system before worrying about the valves at this point.
Have the valves ever been adjusted? 33k miles is a lot if not.
#WordCrimes
SkyDork is offline
post #5 of 10 Old 06-22-2012, 02:45 PM Thread Starter
he hasnt had them adjusted, hes had it for 8k
Livin The Dream
post #6 of 10 Old 06-22-2012, 02:45 PM Thread Starter
also sid it doesnt seem as powerful as it was
Livin The Dream
post #7 of 10 Old 06-22-2012, 04:08 PM
i doubt its the valves. THey have to be really out of whack (too tight) to cause symptoms. Its probably something "tune-up" related. Battery/injectors/sparkplugs/tune
mityaz is offline
post #8 of 10 Old 06-22-2012, 04:46 PM
All show and all go 10r
JLG0987's Avatar
Originally Posted by mityaz View Post
i doubt its the valves. They have to be really out of whack (too tight) to cause symptoms. Its probably something "tune-up" related. Battery/injectors/sparkplugs/tune
JLG0987 is offline
post #9 of 10 Old 06-22-2012, 05:10 PM
TexasRider's Avatar
Do a tune up on it..plugs..air filter..oil change...check the battery on a charger. If its the stock battery and the bike has ever sat awhile without running..id even just replace the battery.
Faster than a drunk snail on valium!
07 zx10r- stolen
New bike...07 GSXR1000..BMC filter, LOR slip on, 520 conversion with -1, speedohealer, pc3 custom map with xtre settings, Galfer superbike lines front, galfer sportbike line rear, shorty levers, Yami R1 throttle tube for 1/5 throttle, PAIR mod, exhaust valve gone, ecu flashed.
TexasRider is offline
post #10 of 10 Old 06-22-2012, 05:12 PM
check your exup valve is working. i fitted mine wrong way round when i had fzr1000 and got destroyed by a vfr400. the shame. worth a check
seddo is offline
Valves/Oil nakedinseattle Suspension and Tire Tech 1 05-26-2014 09:39 PM
Gen 1: Bad clutch symtoms Heavyweight Performance and Tech 2 03-23-2012 04:49 PM
Just did my valves FXSTCHIEF Performance and Tech 5 12-20-2009 01:33 PM
For those who've done their own valves... lenshead Performance and Tech 5 07-01-2009 11:29 AM
F---in' Valves...WTF??? lenshead Performance and Tech 4 05-07-2006 01:13 AM
