Idleing high after butterfly removal?????? - Kawasaki ZX-10R.net
post #1 of 47 Old 09-22-2010, 11:03 PM Thread Starter
BANNED
so i have been reading thoroughly about removing the flies so i did tonight. Now i went out to test it and it ran great but it wont come down any less than about 3700-4000 rpm's. i tried the idle adjusting screw and got it to idle higher but not any lower. what could be the issue? any help would be great ! thank you in advance.
jeremiah is offline
post #2 of 47 Old 09-22-2010, 11:47 PM Thread Starter
BANNED
also if i turn the throttle closed it seems to help it a bit but that would be a pain in the rear to have to do all the time.
jeremiah is offline
post #3 of 47 Old 09-22-2010, 11:52 PM
Certified SLOW
nolaZX10's Avatar
Weird, I swear somebody else said something similar. Yet, I had the complete opposite problem. I actually had to raise my idle after removing them. However I also installed TRE at the same time.
nolaZX10 is offline
post #4 of 47 Old 09-22-2010, 11:54 PM
Velociraptor's Avatar
Something is wrong there. Throttle cable ? sensor pluged on the airbox?
Velociraptor is offline
post #5 of 47 Old 09-22-2010, 11:56 PM
Teeks's Avatar
I would definately recheck your work. removing the secondaries should not have that effect at all. Like stated above, something pinched, sensor unplugged, forgot to plug a vacuum line back in.
Teeks is offline
post #6 of 47 Old 09-23-2010, 12:00 AM Thread Starter
BANNED
ok good!!! i am glad that you guys posted so quickly. I thought i got everything back together but i am going to go double check now.
jeremiah is offline
post #7 of 47 Old 09-23-2010, 12:15 AM Thread Starter
BANNED
well the main hose to the bottom of the airbox was off. hooked it back up and still pretty much the same thing. except now i am at about 1700-1900 RPM's.
jeremiah is offline
post #8 of 47 Old 09-23-2010, 12:17 AM
Dont mess wit White Ninja
abzx10r's Avatar
to the throttle cable...something is pulling!
abzx10r is offline
post #9 of 47 Old 09-23-2010, 12:22 AM
utahmike's Avatar
ha did the same thing. mine was there was a vacume hose pulling the throttle cable tight.
utahmike is offline
post #10 of 47 Old 09-23-2010, 12:30 AM Thread Starter
BANNED
got the airbox off now. it looks like the primaries are closing all the way but when i roll forward a little they shut just a bit more like maybe 1/3 cm (if thats a number) i dont know? im skerd to turn out the idle too much and have the adjuster come out cause i turn it in till it idles up then turn it out till it wont go down anymore. i dont know cables look good. there is not much in there that can mess with them.
i also have Ivans TRE on there. Would that make a difference?
jeremiah is offline
What to do Butterfly removal problem Bigcat#44 Performance and Tech 31 01-13-2010 06:35 PM
Butterfly second erikspeed Race and Stunt 7 03-31-2008 01:48 PM
Exhaust Butterfly Valve Actuator Plug Connector removal kawaboy Performance and Tech 3 11-20-2007 04:48 PM
butterfly valve removal scream-n-10r Performance and Tech 11 10-19-2006 09:51 PM
Butterfly Exhaust Valve Actuator Removal. blipfth Performance and Tech 48 09-14-2004 08:35 PM
