Gen 3: 2008-2010 idle stutter - Kawasaki ZX-10R.net
post #1 of 5 Old 06-19-2012, 07:56 PM Thread Starter
idle stutter
so i just bought this bike about a week ago now. has close to 14k miles on it and just had an oil change done 1000 miles ago. when i turn the bike on as a cold start it tends to die immediately (unless i gas it for a few seconds) once it has warmed up, the bike idles with a stutter, but doesnt die.
now the bike as far as i know, only has a full leo vince exahust system added to it.
This is my first 1000cc and i never had this issue with my 600cc's, even on cold starts. so im just wondering if this is a common issue with 1000's
thanks for reading
EDIT: forgot to say bike idles at 1k so i dont think idle needs to be turned up but i could be wrong.
dgarcia1688 is offline
post #2 of 5 Old 06-19-2012, 08:15 PM
badassjake's Avatar
open it a tad bit to say, 1,300rpms and see how it responds
badassjake is offline
post #3 of 5 Old 06-19-2012, 08:20 PM
SkyDork's Avatar
Idle setting should be 1,150 +/-150 RPMs. Try upping it slightly as the first step to troubleshooting this.
The idle up circuit should kick in when it's cold and keep a higher idle initially and then settle down to what you set. but if it dies right away cause of a lower idle setting, it may be causing some issues.
#WordCrimes
SkyDork is offline
post #4 of 5 Old 06-19-2012, 09:05 PM Thread Starter
oh ok see i thought it was supposed to be set at 1k rpms. i will def up that a tad and see how it responds. thanks for the tips, greatly appreciate it
post #5 of 5 Old 06-21-2012, 05:59 PM
BratNetwork's Avatar
I noticed when I took my secondaries out that the idle wasn't as smooth and I had to tweak the idle a bit to get it to be ok, but even at that it wasn't as consistent as I'd like. I got an ECU flash and put the secondaries in and never looked back... I would check to see if the secondaries are there or not if you still aren't satisfied after bumping the idle up.
2008 ZX-10R | Black | Arrow Headers | AreaP Slip-on CF | K&N Filter |GUTS ECU Flash By Guhl Motors | Block-Off Plates | Fender Eliminator | Clear Alternatives Integrated Taillight | Rifleman's 1/5th Throttle Insert | Speedohealer | Pro-Grip 719s | Vortex Bar Ends | Puig Z DB Windscreen | CBR1000 Mirrors | Vortex 520 Sprockets -1/+1 | RK Gold 520 Chain | Galfer SS Lines | Pazzo Shorty Levers | Vortex Gas Cap | Rebuilt Damper | Lightech Rearsets | Much More To Come
BratNetwork is offline
Sub 3000rpm Stutter and rough idle scott22neale The ZX-10R 61 06-19-2012 05:33 PM
Gen 1: rough idle stutter below 3k rpm poyter789 The ZX-10R 6 04-04-2012 05:50 AM
05 ZX10R Stutter... GRKZX10R Performance and Tech 8 09-23-2011 04:55 PM
Sub 3000rpm Stutter and rough idle scott22neale Performance and Tech 1 08-02-2010 03:46 PM
08 zx10r high rpm rev stutter snowy10r Performance and Tech 1 05-24-2010 03:30 AM
