idle speed problem (2004 ZX) - Kawasaki ZX-10R.net
post #1 of 8 Old 06-05-2007, 02:24 AM Thread Starter
Hi guys
Well my 10 has 23500km(14000mi) and tomorrow i am going to service it but although it runs perfect,with the engine warm-hot at idle, the idle speed is not stable.
It varies between 500rpm and 1300rpm,and when at the bottom it feels like it will stall,but then goes up again,finally after 2-3 min it seems to stabilize at the proper 1100rpm.(The only modification on the bike is an akrapovic slip-on without PCIII or air filter.)
Any ideas?
THANK YOU!
K.makry is offline
post #2 of 8 Old 06-05-2007, 07:17 AM
FAF
Rent this space
Its probably loading up a little at idle (mapping) , did you calibrate your throttle position sensor with your PC111 ??
FAF is offline
post #3 of 8 Old 06-05-2007, 07:44 AM
Uh...I'll bet the answer to that is "no".
wash23 is offline
post #4 of 8 Old 06-05-2007, 07:47 AM
Yankee Racer
zx10ragentblack's Avatar
Images: 9
Send a message via Yahoo to zx10ragentblack
Moved here:
JJ
zx10ragentblack is offline
post #5 of 8 Old 06-05-2007, 09:55 AM
ZX10Rip's Avatar
Originally Posted by K.makry View Post
Hi guys
Any ideas?
THANK YOU!
You might try to syncronize the throttle bodies when you do your service. They may be out of sync with that many miles on the bike.
ZX10Rip is offline
post #6 of 8 Old 06-05-2007, 03:21 PM
Gone
tony83 is offline
post #7 of 8 Old 06-05-2007, 03:35 PM
Post Whore
1killer1liter's Avatar
Images: 11
There might be a vacuum leak.
I live my life a quarter-pounder at a time. And for those 500 calories or more, im free. I need FRIESSSS! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didnt blow a seam on your nugget box.
1killer1liter is offline
post #8 of 8 Old 06-07-2007, 04:47 AM Thread Starter
We did just that(syncronize) and now runs fine.
THANK YOU
K.makry is offline
Idle RPM nachszx Performance and Tech 14 04-21-2007 12:36 PM
Idle Speed Adjust BigDally The ZX-10R 4 10-09-2006 06:57 PM
2004 Generator problem Rider Performance and Tech 1 10-29-2005 07:28 AM
2004 zx10r problem need help guyinhershey The ZX-10R 9 09-02-2005 05:32 PM
Idle Problem...Maybe gguff The ZX-10R 14 03-02-2005 04:36 AM
