Idle issue stuck at 7k rpms!! - Kawasaki ZX-10R.net
post #1 of 38 Old 03-04-2010, 07:36 AM Thread Starter
06TENR's Avatar
I did a search but didn't turn anything up....
My bike recently has been having issues with the idleing.
When i start the bike up it runs fine but if i rev it up past 7000 it falls and sticks at 7000 rpms. If i twist forward on the throttle it will die.
Lastnight we pulled the throttle cables lubed them found no kinks or anyitng, reinstalled them and the problem still existed.
Also pulled the throttle bodies, inspected them, they are super clean couldn't find any issues.
Unplugged the powercommander and tried again... Problem is worse w/ powercommander unplugged.. When it was unplugged it as soon as you start the bike it would instantly rev up...
Im torn on what this could be, does anyone have any advise? Or has anyone had this problem?
Thanks guys
06TENR is offline
post #2 of 38 Old 03-04-2010, 07:56 AM
sextaafondo's Avatar
The cause to this is usually a TPS gone bad.
Is your bike showing an FI code? (red led blinking)
The TPS check procedure starts at page 3-50 for the main TPS, and 3-80 for the subthrottle TPS, in the service manual.
sextaafondo is offline
post #3 of 38 Old 03-04-2010, 09:12 AM Thread Starter
06TENR's Avatar
No lights blinking... No fi light..
06TENR is offline
post #4 of 38 Old 03-04-2010, 09:31 AM
OK then. Raise the tank to gain access to the air box; open the air box, start the engine, and look at the secondary butterflies movement.
If you see erratic movement of them OR they are partially or about completely closed when the engine is idling around 7000rpm then one of the TPS is bad, even if there's no FI code (Normal position of the secondaries at normal 7000 rpm is fully opened).
In that case do the checking procedure according to the pages in the service manual I indicated you.
post #5 of 38 Old 03-04-2010, 12:04 PM Thread Starter
06TENR's Avatar
Right on man, thanks a lot!! I will get that checked out tonight
06TENR is offline
post #6 of 38 Old 03-04-2010, 12:35 PM
post #7 of 38 Old 03-04-2010, 02:17 PM Thread Starter
06TENR's Avatar
Soooo i just contacted the kaw shop and to replace the sensors they say you have to buy the whole throttle body assm.. Which runs 1200 bucks.. Anyone have another route to getting these parts????
06TENR is offline
post #8 of 38 Old 03-04-2010, 02:45 PM
Sebastian1000's Avatar
Wow that is highway robbery. Good luck. I HATE it when a company tries to sell you some assembly when all you need is a small part!
Me: "I need this bolt"
Them: "Ohh that bolt? Well you have to buy a whole engine for that bolt."
:headshake
Sebastian1000 is offline
post #9 of 38 Old 03-04-2010, 03:12 PM
I've got a bike that i'm in the works of picking up to part out. All i need is the motor, and i'm getting the bike pretty cheap. If you are interested i would be willing to part with what you need for around 1/3 what they want new. The thread is called 04/05 parts feeler.
Scott10r is offline
post #10 of 38 Old 03-04-2010, 03:15 PM
Sorry, i'm an idiot, the bike i am picking up is an 05, so i'm not sure if the peice is interchangable.....
Scott10r is offline
Why is my 05 stuttering at low RPMs? bove The ZX-10R 31 03-30-2013 08:41 PM
Backfiring at 3500 rpms Crazy26 The ZX-10R 20 03-21-2009 03:13 AM
Bad Vibration At All RPMS walkthisway21 Performance and Tech 6 05-13-2008 01:42 PM
10's Rpms @ X mph OneSLOW10 General Motorcycle Discussions 30 04-13-2008 05:34 PM
Finally No More Hole At 7K RPMS ducatiryder89 Performance and Tech 13 12-13-2007 07:50 AM
