IDEA about Gear change and Profile tire change - Kawasaki ZX-10R.net
post #1 of 6 Old 03-26-2010, 03:02 AM Thread Starter
Late Apex
Solo-Six's Avatar
so guys .. if you change your front sprocket to -1 you will throw off speedo .. it will be reading faster than it is going correct
? well couldnt you change your rear tire profile from 190/50 to a 190/55 to compensate and get your mph reading percentage closer to ground zero?
Solo-Six is offline
post #2 of 6 Old 03-26-2010, 04:15 AM
ninja9r's Avatar
The factory error in the speedometer is not compensated though, and even if 190/55 compensates for the -1 front, you're nowhere near ground zero. I have this exact setup in my '04 and when i installed speedohealer i had to dial in a good -8% (measured by gps in various speeds) to correct the speedometer reading.
ninja9r is offline
post #3 of 6 Old 03-26-2010, 06:45 AM
TENN10's Avatar
Images: 145
Use a speedohealer to correct your speedometer.
What would be the point in going -1, if you change your rear tire to try to compensate?
I could see running a 190/55 and not being happy with the tall gear, then going -1 or +2, etc.
TENN10 is offline
post #4 of 6 Old 03-26-2010, 08:05 AM
too true, they would work against each other... so you're going back towards where you started.
i hate forums is offline
post #5 of 6 Old 03-26-2010, 09:24 AM
ninja9r's Avatar
From a theoretical view:
A change from 190/50 (1654.991 mm perimeter in theory) to a 190/55 (1684.836 mm) accounts for 1.80% taller gearing. A change from 17t front sprocket to a 16t, accounts for 5.88% shorter one. So, if i'm thinkink correct here, one change does not eliminates the effect of the other, at least not tottaly.
Anyway, the reason of the 190/55 instead of a 190/50 is that the later is good for Nissan trucks and not motorcycles.
ninja9r is offline
post #6 of 6 Old 03-26-2010, 01:47 PM Thread Starter
Late Apex
Solo-Six's Avatar
well in my defense yesterday was rough .. cause i never even considered that
Solo-Six is offline
Any idea to Change the Mirrors of zx10r 2008 gregory_gr Performance and Tech 25 03-06-2011 11:37 PM
Gear change before/after tune Ninjamaster Performance and Tech 5 05-30-2008 05:14 PM
Change Your Profile !!!!!! bluedevil The Out House 15 07-13-2006 10:03 PM
Gear Change? BryanB Race and Stunt 38 07-10-2006 10:22 PM
Gear Change Question TC24 The ZX-10R 6 04-05-2006 10:09 AM
