I need some 06/07 suspension assistance...searched. - Kawasaki ZX-10R.net
post #1 of 10 Old 08-25-2008, 09:22 PM Thread Starter
VolksDragon's Avatar
So I just picked up another 10R, a brand new '07, and I am starting to get it set up the way I like.
I have done all the reading and searching I could, but I wasn't able to find what I needed.
I need to set my suspension sag before I start messing with rebound and compression, but I don't have the equipment or the personnel to pull that off in my garage at the moment.
Are there any riders out there who are around 230-240lbs in gear who have set their sag correctly on the 06/07? Care to share your settings for preload as well as comp/rebound?
Once I have the time and people, I plan on doing it right, but I would LOVE a push in the right direction for the time being.
SETTINGS!! SHOW THEM TO ME!!
VolksDragon is offline
post #2 of 10 Old 08-25-2008, 09:42 PM
CB160's Avatar
So where are ya? Might be some volunteers to assist in the neighborhood.......
'06, Smoked windscreen, Galfer S/S brake lines, GiPro TRE, Speedohealer, Custom lighted fender eliminater, A&R Baffles, "Real" Ohlins Damper, added a seat cowl, so now I'm a true 'poser'..... Power mods - Why? Too much for me already!
CB160 is offline
post #3 of 10 Old 08-25-2008, 09:44 PM Thread Starter
Good call...Fort Collins, CO.
post #4 of 10 Old 08-25-2008, 10:02 PM
Big Daddy's Avatar
Images: 38
that would be a road trip for CB..........
suffice to say the basic sag settings for the vast majority of bikes is the same and then once you manage some mileage perhaps a lill adjustment here and there but 33-35mm of riders sag up front and 28-32mm for the rear as a start. there are also basic comp/rebound settings too but to try and convey here is a bit tedious and more than likely end up with nothing more than confusion.
Volks PM me your email addy and i'll send a PDF file for suspension.
Big Daddy is offline
post #5 of 10 Old 08-25-2008, 10:06 PM
CB160's Avatar
As much as I would enjoy the ride, I gotta be at work
BD has some good info.....good luck with the adjustments (a little at a time!!)
CB160 is offline
post #6 of 10 Old 08-25-2008, 11:27 PM
At your weight, you need to replace the springs (front and rear) at a minimum. You can make it better without, but it will still suck.
Best to just dump the rear shock and go aftermarket.
TN10R is offline
post #7 of 10 Old 08-25-2008, 11:32 PM
FuTAnT's Avatar
Images: 7
+1, given your weight, no matter how much you preload the rear given the linkage ratio of the stock bike you probably won't achieve the correct sag. You probably need a (correction) around a 550lb / in spring to even get the thing working right, and if you put that on the stock shock, it would have no capacity to damp it.
Same for the front springs, they claim 1.0kg/mm, but measure differently. You'll most likely need in the vicinity of *proper* 1.0kg/mm springs.
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." Albert Einstein
'85 GSX250S -> '96 ZX6R -> '98 ZX6R -> '00 ZX6R -> '03 CBR954RR -> '04 ZX10R -> '02 ZZR250 -> '06 ZX10R -> '08 KTM 990 ADV
FuTAnT is offline
post #8 of 10 Old 08-26-2008, 12:59 AM
stadanco's Avatar
Im 190lbs and use a 1.0 in the front and had to go way up on the back spring. your gonna need suspension work to make it handle half ass. I had both ends re-valved and it made a world of difference, not as good as ohlins im sure but the bike is balanced now and it cost a lot less coin than the good stuff.
stadanco is offline
post #9 of 10 Old 08-27-2008, 11:38 PM Thread Starter
Thanks for the feedback, looks like the rear is gonna have to go, and the front needs some new springs.
post #10 of 10 Old 08-28-2008, 02:14 AM
FuTAnT's Avatar
Images: 7
2nd hand Penske shocks are generally the best bang for buck you'll get, and just as good as Ohlins.
FuTAnT is offline
Tires (I searched) Pilot143 The Out House 17 11-17-2007 05:14 AM
Some assistance please 06blackpearl Performance and Tech 4 11-01-2007 05:46 PM
clutch help please... already searched brianhknott Performance and Tech 0 03-11-2007 07:39 PM
ZX10.NET Veterans I need your assistance zx10x2 The ZX-10R 32 07-30-2006 07:05 PM
Crate assistance RickRoush03 The Out House 4 05-20-2006 11:32 PM
