I could use a little clutch advice please - Kawasaki ZX-10R.net
post #1 of 6 Old 06-08-2007, 07:00 AM Thread Starter
Otis's Avatar
Had a nasty highside at Mid-Ohio this week. Amungst the other significant damage to my 05' 10R, the clutch isn't working. There is no "damage" to either the cables or the clutch cover, it didn't hit there, but.. the bike fires up fine in neutral but when I pull the clutch in and drop it in 1st it automatically engages. Pulling the lever does nothing. Any ideas what could cause this? I am pulling the clutch cover off tormorrow to take a look but I need help knowing what I should be looking for.
Thanks for any help you might offer.
Chris
It's a free country brother.
Otis is offline
post #2 of 6 Old 06-08-2007, 08:32 AM
FAF
Rent this space
Does the lever still feel like it has tension on it ??
FAF is offline
post #3 of 6 Old 06-08-2007, 09:11 AM Thread Starter
Otis's Avatar
Yes the lever is fine and it still pulls the lever down at the clutch fine. I'm wondering if the puller has a problem.
Otis is offline
post #4 of 6 Old 06-08-2007, 04:57 PM
FAF
Rent this space
Strange, if you still feel clutch spring pressure then it should be opening the stack, if it isnt then the plates may have run dry if the bike was still running on its side, it is possible for them to stick together in a very short period of time if they run dry.
FAF is offline
post #5 of 6 Old 06-08-2007, 05:04 PM
MIA Ex-Mod
Tread70's Avatar
Tread70 is offline
post #6 of 6 Old 06-08-2007, 06:00 PM
SalKhan's Avatar
Send a message via AIM to SalKhan Send a message via Yahoo to SalKhan
Check your throwout rod and bearing(s). If either are bent or off centered, it will cause this problem.
Sal Khan
http://www.thelunchjournals.com - Updated 3/8/08!
SalKhan is offline
need more advice shenanigans The Out House 11 03-02-2007 03:05 AM
I Need Advice dhobbs74 Performance and Tech 5 02-08-2007 02:28 PM
I Need CB 350 Advice BrockLanders The Out House 12 11-14-2006 06:49 PM
CRG Clutch Blk Clutch Lever & Lightech Gas Cap yehzx10r Vendors deals 2 09-25-2006 05:25 PM
slipper clutch & clutch plates... jarhead05 Performance and Tech 14 07-07-2005 03:13 AM
