I知 ditching the race dots for slicks! - Kawasaki ZX-10R.net
post #1 of 16 Old 07-24-2005, 09:10 PM Thread Starter
zrxhooligan's Avatar
Send a message via AIM to zrxhooligan Send a message via Yahoo to zrxhooligan
Talking I知 ditching the race dots for slicks!
I知 wondering if anyone has run Dunlop 195 slicks on the track yet? I知 planning on using them at Autobahn and would like some input.
Dose anyone have any experience with them yet? Good, bad or indifferent?
I知 going from an 180GPA dot race to the 195 slick. I know that the profile of the tire is the same but I still find it hard to believe that the 195痴 (as wide as it is) will still turn in just as fast as the 180.
My track bike has the stock Traxxioned front end and Penske rear shock so maybe some light suspension changes, like dropping the front end or raising the rear ride height will do the trick?
Last but not lest. I壇 like to keep the rear tire hugger on to keep crap off the underside of the bike and shock, but I have heard that the slick will grow a bit (height wise) and this could cause problems with the hugger. Has anyone had any success in shimming the hugger up higher or should I just live with the track crap and clean it later.
TIA
Kyle
zrxhooligan is offline
post #2 of 16 Old 07-25-2005, 08:54 AM
zeta xray's Avatar
If you are referring to the 195/70 x 17 Dunlop, it is NOT the same profile as a 190/50 x 17 Dunlop. It is wider and much taller and requires significant change in suspension set up.
Don't confuse me with facts, my mind is already made up.
zeta xray is offline
post #3 of 16 Old 07-25-2005, 04:59 PM Thread Starter
I guess I wasn稚 clear and should have added that my track bike is set up right now for the 208 GPA 180/55/17 Dot race tires which are significantly taller then the stock 190/50/17.
There was a bit of changing to the set up when I went from the stock 190 tires to the race 180. so much so that my track bike with the 180 makes my stock bike with the 190 feel sluggish on the turn in (which it should being a taller and smaller profile), I like the faster turn in, and that way I知 asking if there is anyone that is running the 195痴 slicks to get a head start on what way I should be going.
Thanks
Kyle
post #4 of 16 Old 07-25-2005, 05:07 PM
Hillbillie Mod
hillcountry10r's Avatar
Images: 31
youre prolly gonna need to lower the rear.
and theres no way youre keepin the hugger on there.
Youre prolly also gonna need to make some suspension adjustments too.
James 3:7,8
hillcountry10r is offline
post #5 of 16 Old 07-26-2005, 01:40 PM
I use Metz 190/55 racetec's.....close but not the same as the bigger Dunlops. In my experience, the bike handles better with the bigger tire. You're either more or less upright or at full lean with 180/55's - the 10R is not stable during mid corner line adjustments with the smaller tire.
I agree you will need to LOWER the rear with the big Dunlop. Get rid of that spacer on the top of the rear shock (if you have OEM suspension) and expect a more stable feel, but a slower turn in. SLower is relative - it will still handle great. You also might need to lengthen the chain. And forget about the hugger. There is no way it will fit. If you insist, you might be able to fabricate some sort of spacer.
Zed10R is offline
post #6 of 16 Old 07-26-2005, 02:35 PM
Ara
LE Post Whore
Ara's Avatar
Ok, heres some of the math for you guys.
A 180/55 tire on a 17 inch rim has an overall diameter of 629.80mm or 24.80 inches
A 190/50 tire on a 17 inch rim has an overall diameter of 621.80mm or 24.48 inches
A 190/55 tire on a 17 inch rim has an overall diameter of 640.80mm or 25.23 inches
A 195/70 tire on a 17 inch rim has an overall diameter of 704.80mm or 27.75 inches
So as you can see, its a pretty big difference.
Ara is offline
post #7 of 16 Old 07-26-2005, 02:38 PM
Ara
LE Post Whore
Ara's Avatar
Also, generally, the higher the profile of the tire, the taller the arc of the tire surface to meet that higher profile which will promote faster turn in, and more contact patch once the bike is leaned over. That is why the 195/70 is such a massive tire but it works so well. It is tall, and has a large contact patch for lots of stability when leaned over.
Ara is offline
post #8 of 16 Old 07-26-2005, 04:26 PM
Hillbillie Mod
Images: 31
Good info Ara, but only one thing you missed...
All tire profiles can be different...so a Dunlop 195/70 may be 27.75 but a Pirelli 195/75 may only be 27.50...all because of the different, steeper or lack of steepness profile.
James 3:7,8
post #9 of 16 Old 07-26-2005, 04:30 PM
Ara
LE Post Whore
Ara's Avatar
Technically, they should not be different, because all the numbers i came up with are by doing the simple math. Now each brand may have a different forming process which would cause differences, but generally speaking, these numbers are a universal system for tire sizing.
Ara is offline
post #10 of 16 Old 07-26-2005, 05:17 PM
Hillbillie Mod
Images: 31
Talking
I think thats a good starting point, but I do think theres more to it.
I think that some tires, being the same size have better/worse turn ins...because of the different profiles.
Like if you took a peice of string, and held it stationary at both ends, you could make different degree archs with the same peice of string. Same as different tire profiles.
James 3:7,8
Race report 23/7 Macke Race and Stunt 12 07-26-2005 11:02 PM
Mladin's column kaw808 Race and Stunt 4 06-27-2005 09:11 PM
My first race on the ZX-10R... Macke Race and Stunt 8 05-05-2005 11:02 AM
