hydraulic clutch - Kawasaki ZX-10R.net
post #1 of 13 Old 06-08-2008, 01:59 AM Thread Starter
hydraulic clutch
has anyone put a hydraulic clutch onto a zx10r? and is it possible?
ORR10 is offline
post #2 of 13 Old 06-08-2008, 08:53 AM
Big Daddy's Avatar
Images: 38
No one here has but i'm not sure if its possible.
Big Daddy is offline
post #3 of 13 Old 06-08-2008, 09:33 AM Thread Starter
ive been doing some more looking around and believe some zx7r had a hydraulic clutch, but i dont know if they are any lighter then a cable clutch anyway!!!
my old man has an fjr1300 might just steal it of his bike!!! not sure how im going to hook it up down at the crankcase!!!!
ORR10 is offline
post #4 of 13 Old 06-08-2008, 12:04 PM
10rmotor's Avatar
Whoa there BD, somebody here has put a hydraulic clutch on a 10R, but its not a bike!
I have a hydraulic clutch system that I use in the car and it works very well. I didn't want a cable system and wanted a normal foot pedal. I used an el-cheapo steel slave cylinder (I think from a subaru) but you could use a wilwood push/pull cylinder pretty easily I think. You only need about 1/2" of movement at the end of the clutch lever on the motor.
10rmotor is offline
post #5 of 13 Old 06-08-2008, 01:59 PM
Big Daddy's Avatar
Images: 38
then no one has still yet to put one on a bike so i'm still correct.
post #6 of 13 Old 06-09-2008, 06:59 AM
SkyDork's Avatar
Just curious why you would want a hydraulic clutch on the -10R? They are heavier systems than a cable equivolent and the feedback is generally not as good as a cable setup. Most OEM's ditched the hydraulic setups in favor of cable-operated clutches for a reason.
#WordCrimes
SkyDork is offline
post #7 of 13 Old 06-09-2008, 07:59 AM Thread Starter
clutch
what i meant is lighter to pull in, i have a problem with my left wrist i cant pull the clutch after riding for an hour or so!! not a real problem was just curious myself!!! i see the zx14 have a hydraulic clutch setup was looking at how it works on the crankcase, looks to much trouble to even think about doing it!!! unless you can get a unit that has push pull system on the line!! but again never seen that before. my oid man rides a fjr1300 with hydraulic clutch and its so much llighter just like using the front brake!!! but anyway thought id still look into it a bit more!!!
ORR10 is offline
post #8 of 13 Old 06-09-2008, 08:00 AM
jtemple's Avatar
I figured the reason was to save money.
jtemple is offline
post #9 of 13 Old 06-09-2008, 09:16 AM
firerescue212's Avatar
Images: 11
Hey ORR10 Leme know what you find out I too have very limited strength in my left wrist (see avatar) I have been thinking of doing that to mine too, seems a shame to jerry-rig such a perfect bike but its WAY beter than having to sell.
If you haven't gone down yet, you ain't ridin hard enough!!!
firerescue212 is offline
post #10 of 13 Old 06-09-2008, 06:11 PM
10rmotor's Avatar
He didn't specify bike, so I'm right
I think they did it to save weight, and it probably is cheaper too. No cable to bleed either.
My application is in a car, and even though hand clutch levers have been used in cars, mine was already set up with a pedal for the old zx10 which had a hydraulic system. It was relatively easy to adapt a slave cylinder to the new motor so it was a no brainer really. The clutch feel is just fine through the pedal.
I'm not sure what sort of structure is around the clutch lever so I can't say for sure how hard it would be to put a slave on the bike. I'm sure given enough time and money it could be done.
10rmotor is offline
Brembo Hydraulic Clutch for an '07 Kagetsuya Performance and Tech 11 01-08-2009 08:58 AM
CRG Clutch Blk Clutch Lever & Lightech Gas Cap yehzx10r Vendors deals 2 09-25-2006 05:25 PM
04/05 ZX10R Hydraulic Clutch Conversion? Larry Grogan The ZX-10R 11 02-22-2006 10:23 PM
slipper clutch & clutch plates... jarhead05 Performance and Tech 14 07-07-2005 03:13 AM
rear hydraulic brake switch for the 10R-$15 shipped steves87 Parts, Gear and Accessories 6 05-20-2005 05:04 PM
