hurry TRE/TPS ADJUSTMENT HELP! - Kawasaki ZX-10R.net
post #1 of 10 Old 06-02-2007, 10:27 AM Thread Starter
inappropriate
hesaves0211's Avatar
Images: 67
Its saturday and precious riding time is wasting away! i have the tre in and tps cover plate aka bitch plate removed. that little knob i have circled is what you turn counter clockwise forward right? why wont it turn!!!??:(
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #2 of 10 Old 06-02-2007, 11:54 AM
Still here
ZX10Miami's Avatar
Whoa- hope you didn't screw anything up.
Not supposed to remove the cover.
You only needed to loosen the two security torx bolts just enough to rotate the whole assembly forward. The bolt holes only let it rotate so much, don't force it.
Sarah Palin and friends can call it a snow machine all they want but Yamaha, Polaris and Bombardier plus the related magazines all seem to call them Snowmobiles.
Snow machines create snow on ski slopes. Just sayin'
ZX10Miami is offline
post #3 of 10 Old 06-02-2007, 12:01 PM Thread Starter
inappropriate
Images: 67
oh shit. so i losen then rotate damn. lets home im good.
post #4 of 10 Old 06-02-2007, 12:05 PM
Still here
ZX10Miami's Avatar
As long as nothing moved when you took the cover off, you might be okay.
Maybe it only lines up one way?
post #5 of 10 Old 06-02-2007, 12:43 PM Thread Starter
inappropriate
Images: 67
well i just threw everything back together, started it up and it idled around 2-2500 for a couple secs then fell below 1k but if i read correctly theres a lil screw you adjust for that if it bothers you? bout to take it out for a test run along w the new 1/5th throttle mod ;)
post #6 of 10 Old 06-02-2007, 12:44 PM
Still here
ZX10Miami's Avatar
You can probably get away with just adjusting the idle knob at left knee rather than the whole idle screw thing- I did.
post #7 of 10 Old 06-02-2007, 01:02 PM Thread Starter
inappropriate
Images: 67
ok wasnt trying to get it wide open around the neighborhood but there was a significant change. the only complaint i have is the popping sound i get coming from my air box/throttle bodies when i rapidly decelerate
post #8 of 10 Old 06-02-2007, 06:38 PM
jcinfo's Avatar
Hi, just turne the sensor, not removed !!
http://smartexpert.free.fr/photos/tre.htm
hop fotos :)
T.R.E, Power Commander,Hub-003, wide band,LCD Display, Quick Shifter, Yoshimura TRS.
jcinfo is offline
post #9 of 10 Old 06-02-2007, 07:11 PM
Still here
ZX10Miami's Avatar
That'll happen.
A good map will help and you'll be wasting fuel without a tre ready map.
The kleen mod will eliminate a huge part of the popping but not necesarilly all of it if you still have stock headers like I do.
Ivan said some of the popping is the shape or design of the stock headers, the rest is air being pumped in to burn off the wasted gas.
post #10 of 10 Old 06-03-2007, 06:43 AM Thread Starter
inappropriate
Images: 67
Originally Posted by ZX10Miami View Post
That'll happen.
wow, i never knew that. i always expected that popping was an exhaust thing as it was on my r6.
TRE-TPS adjustment, good or not? Infamous Performance and Tech 26 06-03-2007 05:01 PM
Better hurry! Limited supplies! SkyDork The Out House 23 05-06-2007 09:02 PM
Hurry, call now before they're sold out! gpz1100 The Out House 3 11-01-2006 05:30 PM
hurry up and weight Big Daddy Race and Stunt 28 04-02-2006 12:11 AM
headlight adjustment JodyH Performance and Tech 7 10-14-2005 10:31 AM
