Hugger Removal Mod (easy access) - Kawasaki ZX-10R.net
post #1 of 2 Old 07-31-2007, 12:27 PM Thread Starter
Gone
This is a non reversible mod, as you will be trimming the hugger. Although it will make it easier to take your hugger off when giving the bike a good wash to allow access to the inner face of the swinging arm etc. No more spending half an hour with a small hex key or even worse having to take the wheel out to get the hugger off!
Parts needed:
1x rubber wellnut and matching screw. (like the ones in your screen)
1x flattened P-clip/hose clip (will already have two holes in it) or a thick
feeler blade gauge with a second hole drilled into it, or something similar.
As you can see from the pics its fairly simple, just trim the hugger flush to the swingarm and once the homemade bracket is in place line it up and drill a corresponding hole in the hugger near the brake hose clip one. As you can see from the pics there is plenty of clearance so no need to worry about the tyre
Attachment 40895
Attachment 40896
Attachment 40897
Attachment 40898
Attachment 40899
And there you have it; easy on, easy off
tony83 is offline
post #2 of 2 Old 07-31-2007, 12:30 PM
ANIKI_THE_EXILED's Avatar
Send a message via AIM to ANIKI_THE_EXILED Send a message via Yahoo to ANIKI_THE_EXILED
good to know, thanx
I'll see you another goodbye
ANIKI_THE_EXILED is offline
how easy is it to come up ? performancezx10r ZX-6R & ZX-6RR Archives 5 03-07-2007 02:39 AM
How to access the vacuum pipes on a 06 smason5 The ZX-10R 3 06-05-2006 08:01 AM
FS: 2003 R1 easy fix trackaddict Parts, Gear and Accessories 2 03-01-2005 07:47 AM
Access to Euro Microfiche Johnnyboy The ZX-10R 0 02-09-2005 04:34 PM
Anyone have free access to Carfax? steves87 The Out House 1 02-03-2005 01:32 AM
