hp limit - Kawasaki ZX-10R.net
post #1 of 14 Old 05-29-2013, 04:35 PM Thread Starter
gazx10's Avatar
hp limit
what do u think the hp limit is with stk. pistons, 08 race int, , stk. ex. cam, stk. springs, head mods, race gas?
gazx10 is offline
post #2 of 14 Old 05-29-2013, 04:48 PM
nakedinseattle's Avatar
one million
nakedinseattle is offline
post #3 of 14 Old 05-29-2013, 05:42 PM
keithk's Avatar
two million?
Its green and it says Kawasaki ninja zx10r on it!
keithk is offline
post #4 of 14 Old 05-29-2013, 05:59 PM
zx-sik-r's Avatar
You mean potential? Or most you will see out of it?
zx-sik-r is offline
post #5 of 14 Old 05-29-2013, 06:04 PM
moshpete's Avatar
188. on race gas
moshpete is offline
post #6 of 14 Old 05-29-2013, 10:16 PM
SpazOnaZX's Avatar
What gen? Stock pistons have lived at 10lbs of boost for me so far........
SpazOnaZX is offline
post #7 of 14 Old 05-29-2013, 10:25 PM
Post Whore
URBAN LEGEND's Avatar
Images: 13
The limit is your wallet. That's the limit. It's harder to stop wasting money before finding that said limit.
15 Camaro Z/28
16 BMW M5
Former bikes: 07 R1/08 10R/10 S1000rr/11 10R
URBAN LEGEND is offline
post #8 of 14 Old 05-29-2013, 10:26 PM
Post Whore
Images: 13
You will be surprised that in most cases the rider is the one far from the limit.
15 Camaro Z/28
16 BMW M5
post #9 of 14 Old 05-30-2013, 12:44 AM
JLAudio11's Avatar
Deck the head as much as possible, thin hg, stock springs will make more hp than stiffer as long as they last, good port on the exhaust side, full exhaust, no air filter, all short stacks, secondary shaft & flies removed, 520 chain, ceramic bearings, swb, best fuel you can get maybe high 180's/low 190's. It's also very dependent on dyno.
'06 "Corn Burner" Edition ZX10R
w/ a lot of bolt-ons
PERFORMANCE CYCLE 2 Racing
JLAudio11 is offline
post #10 of 14 Old 05-30-2013, 02:55 AM
thundercoupe9's Avatar
the more you deck the head, the less ptv clearance you'll get, the higher numbers you will have to run cam wise and with race cam and 12.5k rpm rev limit or even 13k rpm rev limit of 3rd gen your hp will peak way past rev limit so you will lose power and gain nothing. Get with a builder and go from there, more sometimes means less. For big bore and short stroke 998cc will need rpms to make more power, higher rpm's will need better parts, I think stock pistons/rods should be ok till 14k rpm or so, so whatever power you can get at that rpm will be your limit. With race gas, proper head/cam combo I think 200hp is possible................but it will cost you.
thundercoupe9 is offline
06-07 ECU with *NO REV LIMIT* dsabat Parts, Gear and Accessories 2 08-28-2011 08:22 AM
Gen4..rev limit??? Stucknmawayz The ZX-10R 11 06-21-2011 11:23 PM
Sig size limit? Gho3t ZX-10r.net Site Help, Suggestions and Questions 3 08-17-2008 06:49 AM
80KPH Speed Limit. IITravel Pictures and Videos 1 11-13-2006 11:02 AM
speed limit on tires grego10r The ZX-10R 15 05-17-2005 05:40 PM
