How to open the headlights - Kawasaki ZX-10R.net
post #1 of 10 Old 05-10-2007, 06:37 PM Thread Starter
Hello!
in the past i saw some rebulided headslights on a 10r - i think it called "angel eyes". could somebody tell me how can I open the light without to destroy it? i tried it with a very small cutting disc, but it was'nt successful
I'm curious about your suggestion ...
Greetz from Frankfurt, Germany!
Bye TOX!
TOXIC is offline
post #2 of 10 Old 05-10-2007, 06:47 PM
MIA Ex-Mod
Tread70's Avatar
If memory serves me right, I believe members put the headlight assembly into the preheated oven at like 200-210f for like 10 mins to soften the sticky stuff holding the lenses onto the back.
Tread
Tread70 is offline
post #3 of 10 Old 05-10-2007, 06:48 PM
As far as I know, you disassemble everything you can from the headlights, then put the rest in the oven (not sure on the exact temp setting) then take it out once the glue that holds the headlight together is softened and stick a flat head screwdriver in the sections that are glued to take it apart.
However don't quote me on this cause the above information explains how it's done on subaru cars, not sure if same method is needed for the 10r.
Hattori Hanzo is offline
post #4 of 10 Old 05-10-2007, 07:09 PM
Green Hippie
treyzx10r's Avatar
I used a heat gun and a couple of old butter knives but it still was'nt pretty:headshake
VAE VICTUS!
treyzx10r is offline
post #5 of 10 Old 05-10-2007, 07:10 PM Thread Starter
in the oven? that sounds dangerous. i think its better to heat only the glued part of the light. for sure, it needs a bit more patience, but i hope the result is the same. tommorow I will look for a "hot air pistol" (is this the right english name for this ) i'm afraid that the light can be warping in the oven
I'm still open for any constructive suggestions!
TOXIC is offline
post #6 of 10 Old 05-10-2007, 07:17 PM
Green Hippie
treyzx10r's Avatar
heat gun /hot air pistol we know what ya mean be careful with that heat gun it gets real hot real quick. keep it moving , do'nt let it sit in one spot too long it will melt your plastic
VAE VICTUS!
post #7 of 10 Old 05-10-2007, 07:21 PM Thread Starter
OK Guys, THX a lot, i will try it!
TOXIC is offline
post #8 of 10 Old 05-10-2007, 07:27 PM
rocketracermike's Avatar
post some pics when your done with the project
rocketracermike is offline
post #9 of 10 Old 05-11-2007, 03:21 AM
Doing it in the oven would be safer, easier and would take less time imo. First of all you wouldn't have to worry about not burning anything and moving the heatgun constantly. Plus by the time you are finished with one part the other part would be cold. Whereas the oven would loosen up all the sticky parts at once.
Whenever you see a subaru wrx with clear blinkers you know the headlight been in the oven.
post #10 of 10 Old 05-11-2007, 03:17 PM
OMG Look at that squid!!
trackaddict's Avatar
Images: 51
I hear the low temp oven method is the tricky...
Because wheelie!!!
17' Honda 1000RR SP - 08' Hypermotard 1100s
16' ZX10R - SOLD
14' Ducati Monster 1200S - SOLD
13' RSV4-R - SOLD
My ZX10R's 11' - 08' - 07' - 05' - 04' - ALL SOLD
Miss my Black 04' the most!
Never enough money, never enough time!
trackaddict is offline
Headlights omaharider The ZX-10R 6 06-16-2006 08:48 PM
headlights ORANGE10R The ZX-10R 49 04-25-2006 04:24 PM
05 headlights wicked The ZX-10R 24 03-23-2006 01:34 AM
Headlights? Eddyo Performance and Tech 7 01-04-2005 09:04 AM
headlights zixxer The ZX-10R 9 03-02-2004 07:12 AM
