How to lower your foot pegs - Kawasaki ZX-10R.net
post #1 of 6 Old 02-08-2008, 02:24 PM Thread Starter
S.ga.rider's Avatar
I read on some other forums that you can adapt the buell rider footpegs(part #n0006.1ad) for certain bikes. I decided to give it a try. I bought the pegs from a dealer on ebay. They cost $25 shipped, about $30 from the dealer. The buell pegs are a bit different than the 10s and need moderate modification. An easy task with a bench grinder and a dremel. The problem is they are too wide, too deep and the bolt hole is to small. I opened to bolt hole with a drill bit the size of the stock 06 10 bolt. Then it was a lot of trail and error with the bench grinder to get them just right. you have to remove a good bit of material from the back, top and bottom of the pegs. Fortunately they are very thick and have plenty of material. I ground them down to fit, installed the bolt and clip and then readjusted the shift lever and brake lever. It probably took me an hour to 1 1/2 hours and that was because I tried to dremel it before going with the bench grinder. (that was a lot faster). For $25 and a hour of time you get a minimum of 1" lower pegs. They are noticeably more comfortable than stock. After everything is back together remove the peg feelers and you are ready to go.
Name:	100_0719 (Small).jpg
ID:	58015   Click image for larger version
Name:	100_0720 (Small).jpg
ID:	58016   Click image for larger version
Name:	100_0721 (Small).jpg
S.ga.rider is offline
post #2 of 6 Old 02-08-2008, 02:33 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
Don't know how hard you ride, but what kind of ground clearance did you loose with those things? I ground the feelers pretty good a few times on the stock rear sets, when I had them.
9R to 10R is offline
post #3 of 6 Old 02-08-2008, 02:44 PM
OMG Look at that squid!!
trackaddict's Avatar
Images: 51
Pretty cool and cheap mod. Just an FYI 9r. If you buy Vortex rear sets and flip the frame fitting bracket left to right, you then can use the lowest setting on the bracket to obtain a 1" lower peg. I ride very hard (well knee draggin in Arkansas and at the track) and have not drug peg yet. See my avatar.
trackaddict is offline
post #4 of 6 Old 02-08-2008, 03:00 PM Thread Starter
S.ga.rider's Avatar
I just put them on but dont see a problem. If I were to do a track day I would put the stock pegs back on but for general riding these are great....and a lot cheaper than vortex.
post #5 of 6 Old 02-08-2008, 10:29 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
Was asking more for others that might be interested, the feelers just looked exceptionaly big on those.
I have Rizomas on the 06 and I have nver seen rear sets with more adjustability than these, I have Harris on the 04 no complaints bout those either.
Well anyway, glad you like the buel pegs, they look almost factory.
post #6 of 6 Old 02-08-2008, 10:45 PM
curiousmike's Avatar
s.ga -- i did the exact mod late last year --- it's great.
i've been lightly knee-down with them on, and didn't touch the hero-bobs.
however, as you mentioned, if i was doing a track day, i'd put stock pegs back on.
curiousmike is offline
06 zx-10R passenger foot pegs?????? Jedwin The ZX-10R 43 10-22-2006 12:21 PM
Foot Pegs B1GPAP1 The ZX-10R 7 07-09-2006 09:48 AM
Stock foot pegs vegasdude Wanted: Buy or Trade 3 07-21-2005 01:40 AM
non-oem foot pegs bikerscum The ZX-10R 9 01-13-2005 04:47 PM
Looking for foot pegs? sabersaw30 The ZX-10R 13 08-17-2004 08:22 PM
