how to keep the front off the ground to work - Kawasaki ZX-10R.net
post #1 of 26 Old 08-20-2012, 07:52 PM Thread Starter
cookmaster30's Avatar
need to do fork seals on my gen one and wondering how you guys lift the fron to do the fork seals.
pics are a plus
cookmaster30 is offline
post #2 of 26 Old 08-20-2012, 08:13 PM
blownhotrodder's Avatar
Hang straps from the ceiling in the garage while the rear sits on a rear stand. Loops straps under the triple tree.
blownhotrodder is offline
post #3 of 26 Old 08-20-2012, 08:15 PM Thread Starter
thats what i was thinking but wanted to make sure
post #4 of 26 Old 08-20-2012, 08:16 PM
Slow Poke
bgmagma10's Avatar
I just take my front wheel loose with the back on a rear stand and use a jack and wood under the header to keep the front end up. Not the safest but it's what I do
bgmagma10 is offline
post #5 of 26 Old 08-20-2012, 08:19 PM
Teeks's Avatar
Without a doubt a triple clamp lift is by far the best and easiest way, I have however in the past used strong ratchet straps to accomplish removal of front and rear parts. I put the bike on front and rear stands, use a floor jack under the exhaust just as a backup (little to no pressure actually applied to the bike), hang the straps at a good angle so the bike is evenly supported. The jack will help absorb some of the weight and help keep the bike stable along with the straps. For my Honda i had to trim up some wood block to shim under the exhaust to keep it level. I bought a proper lift after doing this a couple of times, but in a pinch, if you are careful it can work ok.
The pic is of the rear so I could remove my swing arm, but same rules apply for the front. Again I dont necessarily advise this, but sometimes ya have to do what you have to do.
P.S. sorry about the huge pic, dont feel like editing at the moment.
Originally Posted by -Op- View Post
Unless Scout says dont do it. Then, really, just do it.
Originally Posted by or10r View Post
I know its blistering fast but you cant outrun ugly.
Teeks is offline
post #6 of 26 Old 08-20-2012, 08:21 PM
Nismomac's Avatar
Car engine lift and a strap and rear stand
Nismomac is offline
post #7 of 26 Old 08-20-2012, 08:25 PM Thread Starter
thanks guys. now just need to get the balls to do the fork seals
post #8 of 26 Old 08-20-2012, 08:26 PM
Teeks's Avatar
Of course there is always option B.......remove everything off the bike to achieve balance, and pull the forks with the frame (just a little extra work)
Teeks is offline
post #9 of 26 Old 08-20-2012, 08:42 PM
elarm1's Avatar
^^ What.... Did..... You.....Do!!!
Candy Burnt Orange
Pazzo Levers Black w/gold buttons, Hotbodies windscreen, smoked lights, BMC filter, Akro Mid pipe, Hotbodies MGP Exhaust, Solo cowl, PCV w/racefit tune, awaiting dyno tune, 6k HIDs, Butterflies removed, Clear alternatives smoked taillight
U.S. Army Vet
2009 Monster Ed. ZX6R track bike!!!
Hotbodies track bodywork, Two Bros Slip on, butterflies removed.
OBAMA FOR ANOTHER FOUR!!!
elarm1 is offline
post #10 of 26 Old 08-20-2012, 08:44 PM
Post Whore
-Op-'s Avatar
Originally Posted by bgmagma10 View Post
i just take my front wheel loose with the back on a rear stand and use a jack and wood under the header to keep the front end up. Not the safest but it's what i do
sent from my motorcycle iphone app
-Op- is offline
Any Recommended Front Fork Work? ZXTEN-R Performance and Tech 2 01-01-2009 01:33 PM
Front light doesn't work YZF Performance and Tech 0 08-20-2008 12:50 PM
Needs work on putting the front down cain772 Pictures and Videos 25 01-01-2007 08:13 PM
ZX10 Front brake doesn't work... Austin10RPowers The Out House 7 08-12-2006 04:52 PM
Front Body work & such for sale dogbone Parts, Gear and Accessories 19 08-20-2005 08:10 AM
