How does preload effect a bikes ability to wheelie? - Kawasaki ZX-10R.net
post #1 of 24 Old 07-05-2005, 06:53 PM Thread Starter
Superbike1's Avatar
Images: 16
Question How does preload effect a bikes ability to wheelie?
How does the preload affect the ability to wheelie? Does it have any effect at all? I wonder if more makes a bike more wheelie prone or if less makes it more wheelie prone? I haven't really tried it on the ten because it is such a bitch to turn the preload collar.Any body have any Ideas about this?
Is it Fast?
Superbike1 is offline
post #2 of 24 Old 07-05-2005, 09:38 PM
zeta xray's Avatar
I don't know....
Having said that, I would think that the suspension settings can effect how easily the bike can be made to wheelie. For example, no rebound damping in the front end would let the weight transfer more easily to the rear. I don't know about rear preload. I understand that as you gas the bike, the rear suspension actually tries to extend due to the action of the chain and the angle of the swingarm. So I don't know how preload would effect things.
Don't confuse me with facts, my mind is already made up.
zeta xray is offline
post #3 of 24 Old 07-05-2005, 09:51 PM
I'm no expert... but my understanding is if you soften the preload, wheel won't come up as quickly
sp500 is offline
post #4 of 24 Old 07-06-2005, 07:28 AM
busaforhire's Avatar
yep your both right your no experts...
preload shouldn't have much effect unless it's set up grossly wrong anyhow the compression damping though..that can make a difference..soften it up and the rear spring will compress more easily. the 10 isn't the best wheelie nike I've ever owned.. the gsxr1000 was much easier to wheelie on in stock form.
05 lime green. Sato slip-on, pc3usb, bmc race filter.
"when ya lose site of why ya ride then you've lost what really matters"---THE MOTORHEAD
busaforhire is offline
post #5 of 24 Old 07-06-2005, 10:22 AM
crispin's Avatar
Send a message via AIM to crispin
Didn't you just get your 10?
Perhaps you need more time before you make that opinion?
I find the 10 to be the easiest bike to wheelie that I have ever been on.
ya ya ya...
crispin is offline
post #6 of 24 Old 07-06-2005, 10:35 AM
then you need to wick up a gixxer 1000 at about 5000 in second.. my ten won't lift from there without some tugging..7-8000 maybe..
I've rode over 750 miles in less then a week on this bike...it don't wheelie if you don't want it to.. simple as that..
is you sprocket size different from stock?? if so i can see that it would wheeilie easier... i didn't say that it didn't wheelie good it's just not as easy as say a gsxr 1000 the zx doesn't have the low end that the suzuki does..
post #7 of 24 Old 07-06-2005, 10:35 AM
by the way i see you have some nice mods done to your scoot.. what was the before and after gains you seen with your combo??
post #8 of 24 Old 07-06-2005, 10:37 AM
zeta xray's Avatar
Obviously, you belong in the no expert group as well. But your opinion is appreciated.
Ever watch a bike on a dyno. What does the rear suspension do when the bike is under load????
post #9 of 24 Old 07-06-2005, 11:11 AM
ughhh compresses...(some bikes much more then others)
post #10 of 24 Old 07-06-2005, 11:19 AM
zeta xray's Avatar
Nope. Most standard bikes jack up in the back when under load on a dyno. They compress back down when the throttle is rolled off. This does not apply to bikes with non-standard geometry. Such as bikes that are lowered. And bikes with extended swingarms will exhibit less effect. That is why they launch better than bikes with standard set-ups.
Settin Suspension Sag hillcountry10r Performance and Tech 20 02-07-2007 04:31 AM
Settin Suspension Sag hillcountry10r How To... 2 02-05-2005 02:29 PM
2004 open class comparison, by 2 oldish fools from Brisbane Afrodesia The ZX-10R 11 06-01-2004 08:50 AM
RedElk's ZX10R Ride and Adventure review swft The ZX-10R 11 03-11-2004 01:24 PM
