How do you remove rivets? - Kawasaki ZX-10R.net
post #1 of 5 Old 08-02-2008, 08:12 PM Thread Starter
ikaika's Avatar
I was looking at the M4 GP slip-on and wondering if anyone knows how to take off the M4 logo piece. It looks riveted on. How do you drill out the rivets?
Custom FE/CA taillight/TechSpec/Driven D-Axis gas cap/Cox Racing/Champs frame-fork-swingarm sliders/Puig ZRacing/Titax/Woodcraft-Attack case covers/SME rear axle block sliders/Misc carbon fiber/ZG Latigo/HID's/M4 Street Slayer/BMC/XTre/EK 520 MVXZ/+4 Drive Sys/SpeedoHealer/HEL 'Stealth'-Motul RBF600-Galfer pads/KyleRacing damper/Rifleman's/Ivans b/o plates/Q3's/Motul 300v/Engine Ice/Shorai
http://www.maresohana.com/ktrsd
ikaika is offline
post #2 of 5 Old 08-02-2008, 08:15 PM
FEELING LUCKY, PUNK ?
Lucky10R's Avatar
Images: 19
with a drill ?
Lucky10R is offline
post #3 of 5 Old 08-02-2008, 08:15 PM
zx7rydr's Avatar
Send a message via MSN to zx7rydr
stick a #30 drill bit in the center of the head and drill down untill just past the head. It should just pop off. If not, use a #20 bit and do the same.
CA green int. brake light, CA green front blinkers, APE manual cct, Kleen air mod (Ivan's), Jumper mod, Full Akrapovich Race exhaust, PC3, Factory Pro Velocity Stacks, Muzzys Alum. Rad. Fan, Factory Pro Shift Star kit, Competition Werks fender elim, Stealth Sprockets (-1, +2), D.I.D ERV3 X-Ring Gold Chain, Speedo Healer, GPR V4, Black/Black Pazzo "shorty" levers, 08 ZX6R Calipers, rockin the pilot powers, more to come...
zx7rydr is offline
post #4 of 5 Old 08-02-2008, 08:17 PM
Rasavong's Avatar
Rasavong is offline
post #5 of 5 Old 08-02-2008, 10:24 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
IF you take if off, you are gonna want to fill the holes with JB weld, or put some blank rivets in the holes, the small holes will drive you crazy, you will definately hear them missing.
9R to 10R is offline
tail section removal, quick rivets alharm1 The ZX-10R 12 04-01-2008 09:20 PM
Plastic Rivets Gang Green Performance and Tech 4 11-11-2006 08:20 PM
Black Plastic Rivets zx10x2 The ZX-10R 7 07-22-2006 08:28 AM
Rivets lunitk Performance and Tech 2 03-27-2006 11:46 AM
Lower rivets? BNninja Performance and Tech 6 09-24-2004 01:54 PM
