How do you get to the air filter to change it - Kawasaki ZX-10R.net
post #1 of 6 Old 05-29-2007, 12:46 PM Thread Starter
Anyone done a how to change the air filter thread. Only got the owners handbook and doesnt show you anything.
Thanks
Expensivetoylover is offline
post #2 of 6 Old 05-29-2007, 12:57 PM
zx10Duran's Avatar
take off the back seat remove bolt holding front seat on remove side panels then use a 10mm socket to loosen tank bolt by the battery, remove 2 bolts up top by triple tree pull tank up carefully not to pull out the rubber hose to hold the tank up tighten the bolt by the battery once you have the tank up where you want it. uscrew the 8 screws holding plastic cover to expose the air filter
zx10Duran is offline
post #3 of 6 Old 05-29-2007, 02:26 PM
Supercharged Mod
The other thing is that it will make life much easier and less risky if you take the fuel tank off completely rather than trying to work underneath it. Suggestion ... arrange for doing this procedure with the fuel tank almost empty, it's a lot easier to handle!!
On the '04 - '05, to take the fuel tank off completely, after undoing the bolts, unplug the connector on the left side that was underneath the left trim panel (leads to fuel pump - you'll find it easy that way). Then you will need to unplug the fuel line. Set the fuel tank down before doing this, switch on the ignition key and crank the engine for a couple seconds. It won't start with the fuel pump unplugged, but this will de-pressurize the fuel rail so that you don't spray fuel everywhere. Now, using your fingers, press together the pink projections on the end of the fuel hose and simultaneously push those projections into the connector. This will push the little pink locking device out of the fuel connector on the other side (doesn't need to come completely out). Then you can pull the fuel hose off, and then take the fuel tank completely off the bike.
GoFaster is offline
post #4 of 6 Old 05-29-2007, 10:44 PM
inappropriate
hesaves0211's Avatar
Images: 67
what a pain in the ass. on my r6 all i had to do is losen the two top tank bolts (by the triple tree) and pull the tank upright about 70 degrees. then remove 6 airbox screws and i was in there.
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #5 of 6 Old 05-30-2007, 05:56 AM Thread Starter
Thanks for info, I`ll have a look this weekend!
Cheers
post #6 of 6 Old 05-31-2007, 12:24 AM
Infamous's Avatar
I can recommend the workshop manual, should be around here somewhere....just print the page you need, works great...
swedish meatball.
Black 2004 with full Yoshi, PC3, TRE, Oggy knobs, C/A smoked tail light and smoked euro front turn signals, servo eliminator, ÷hlins steering damper, kawwi DB screen. thinkin about the air horn...
Infamous is offline
K&N Filter 04 10r ram360 Parts, Gear and Accessories 0 02-15-2007 09:51 AM
K&N air filter bikerscum The ZX-10R 49 06-28-2006 02:34 PM
DNA air filter 1killer1liter Vendors deals 6 04-11-2006 06:09 PM
Best Air Filter?? zx-10r203 Performance and Tech 15 04-10-2006 06:15 PM
K&N Filter out yet? STREETFIGHTER50 Performance and Tech 12 12-30-2004 08:12 PM
