how to clean and wax the chain - Kawasaki ZX-10R.net
post #1 of 24 Old 12-02-2005, 03:37 AM Thread Starter
Images: 9
Need some tool guide and tip how to clean and wax the chain, what you do?
zenithRR is offline
post #2 of 24 Old 12-02-2005, 04:09 AM
Ruthless Racing's Avatar
Images: 9
The best thing I've found to clean the chain with is diesel fuel and a bristle brush. I put the diesel in a spray bottle and the bike on a stand and roll the chain around spraying it with diesel. Then take the bristle brush to the chain until your satisfied and spray off with water. Before spraying the wax on the chain, the chain needs to be warm. Like a ride around the block or so just to get some heat in the chain. I like to have a rag handy to wipe the chain wax off the wheel, swingarm, tire, etc. after coating the chain, then just let it sit for 10-15 minutes so the chain wax can dry. IMO it's best to do this after a ride.
Kenny Poppell
AMA Dragbike SuperSport #1000
2007 AMA Dragbike 1000SS National Champion
2007 1000SS 1/8th ET Record Holder 5.967
Best 1/[email protected] Best 1/[email protected] Stock Wheelbase
Special Thanks:
Performance Psycle
Richies Tires
http://www.XXXRacingFuel.com
http://www.SuperbikeSpecialties.com
http://www.Tsukigi.com
http://www.CycleConceptsRacing.com
http://www.myspace.com/ruthlessracing1
Ruthless Racing is offline
post #3 of 24 Old 12-02-2005, 06:36 AM
V-Force's Avatar
Send a message via MSN to V-Force
I use kerosene to clean the chain.
Doesn't smell as bad as diesel fuel and does not damage the o'rings.
Available at every hardware store.
Then I do the same as ruthless........bristle brush or paint-brush, race stand, put some kerosene in a margarine pot and brush the chain. Then clean the chain and rear tire carefully with soap and water, ride the bike around the block and use a good chain wax.
Kerosene works great on wheels and body work........and it's gentle on paint.
WD-40 works good too for wheels and fairings.
V-Force is offline
post #4 of 24 Old 12-02-2005, 07:06 AM
sneaky's Avatar
I just use WD-40 and some rags to clean mine. Then ride it around the block and apply Maius Chain Wax to mine after that and let it sit until the wax has had some time to dry.
sneaky is offline
post #5 of 24 Old 12-02-2005, 07:53 AM
sneaky (above)
jayrc30 is offline
post #6 of 24 Old 12-02-2005, 08:08 AM
Big Daddy's Avatar
Images: 38
For the most part i address the chain maintenance when returning from a ride when the chain is warm and i use a WD-40 soaked rag to wipe down the chain both inside & out then a dry rag for a final wipe down then apply a liberal amount of Honda HP chain lube to the inside rollers while spinning the wheel and done till the next 500 miles.
Big Daddy is offline
post #7 of 24 Old 12-02-2005, 08:11 AM
Images: 7
I use a product called Motul Chain Clean. Combined with a rag and a brush, it doesn't leave any residue on the chain. That leaves a super clean surface for the lube (PJ-1) to stick to with zero fling.
Fish Slapper is offline
post #8 of 24 Old 12-02-2005, 09:26 AM
Andy's Avatar
Images: 25
I've always had flinging problems with the PJ-1 product. The gold label Chain Wax is my current favorite, it never flies off.
Andy is offline
post #9 of 24 Old 12-02-2005, 09:33 AM
Big Daddy's Avatar
Images: 38
me too. until changing to HP lube i used PJ1 blue label for many years and while the amount of fling is minimal under a days ride it do fling...or is that fly?
post #10 of 24 Old 12-02-2005, 09:47 AM
busaforhire's Avatar
kerosene and the Grunge brush. Its a brush solely designed for chain cleaning and it works great. I then use Maxima chain wax for lube.. I think none of them are great some fling, some attract dirt,.. The most important thing is to just use it.. whatever you use.
05 lime green. Sato slip-on, pc3usb, bmc race filter.
"when ya lose site of why ya ride then you've lost what really matters"---THE MOTORHEAD
busaforhire is offline
Care and Feeding of a DID Chain circusnuts The Out House 3 10-19-2005 03:22 AM
Which chain lube/wax? Balto The ZX-10R 15 06-23-2004 09:29 PM
