How can you rewrite the map of stock ECU? - Kawasaki ZX-10R.net
post #1 of 32 Old 07-11-2005, 12:47 PM Thread Starter
On Kawiforums ,I 've see that someone can rewrite the software to flash the stock ECU then I tried to email him but he want to reply .
I didn't know that one could rewrite the map of stock ECU.
Here's the link:
http://kawiforums.com/forum/topic.asp?TOPIC_ID=33127
Is there someone that can rewrite the stock ECU ?
Yvan
yvanlover is offline
post #2 of 32 Old 07-11-2005, 01:00 PM
If it is some sort of erasable memory or flash memory it is possable to rewrite the code. First step is, find out what kind of format the code is written in (binary, hexidecimal etc). Second, disifer spelling??, the code and find out what portion of the code you are looking at to find the parameter you want to change. Then find the hardware to program your chip. Next make adjustments to the board itself to make the chip removable (some sort of socket). Last learn to write the code and find all the logic involved in the parameter you are trying to change, write the code onto the chip.
snoopnoon is offline
post #3 of 32 Old 07-11-2005, 01:03 PM
what you're looking for is going to be an EPROM. Erasable Programmable Read Only Memory. basically a 'chip' for short. most of the exhaust manufacturers offer them, and in my experience they're virtually worthless.
ZX10dancies is offline
post #4 of 32 Old 07-11-2005, 09:26 PM
The race ecu's for the ZX6 and I presume ZX10 can be changed, BUT they are in blocks. You cannot go in and change 40% throttle at 6000rpm, you can only do it as a whole from up yto 20% throttle, then from 40-80% and then 100%. Why bother?, cheaper to get the PC and get it done right.
Birdman is offline
post #5 of 32 Old 07-11-2005, 11:10 PM
But there are alot of other advantages to programing your own code in the ECU. The bike has a clutch switch and a rev limiter.. which means that when the clutch is engaged the ECU could be programed to have the rev limiter at lets say 8K RPM, so you get consitance launch.. soon as clutch is released.. boom back up to 13k. Another advantage woudl be the timing map that is used.. they are saved to bits which means that you can modify each timing slot in the table. You could have a sequence of events that have to be performed in order for the bike to start.. and the list goes on... IFFFF you know how to program and disifer the original code.
post #6 of 32 Old 07-12-2005, 04:58 AM
Send a message via AIM to gladding24
BTW Yvanlover, TBerd is pretty well known around the motorcycle forums to be a dipshit troll and pot-stirrer. I, personally, would be inclined to doubt every word typed by him unless he has concrete proof to back it up, but that's just me.
If you want to know about remapping the stock Ecu, you need to talk to Marc Salvisberg at Factory Pro here in San Rafael, CA they were working on a tool similiar to the TEKA tool for our ZX10's last year, but I haven't talked to them in a while about it. Let us know what he says if you call.
Here you go:
(800) 869-0497 Voice - Toll Free US and Canada)
(415) 491-5920 Voice
fax 415 492-8803
Stop Whining!!!
It ain't easy being Green ~ Kermit The Frog
Arguing on the internet is like running in the Special Olympics.....Even if you win...you are still retarded
CaliSuperbikes- "these are high strung machines, and we're giving them a constant dose of Red Bull"
gladding24 is offline
post #7 of 32 Old 07-12-2005, 04:20 PM
Supercharged Mod
Some race teams here were using the race-kit ECU with a PowerCommander piggybacked on top of it. They did it this way because the race-kit ECU gave them at least some access to functions not available at all in the PowerCommander, but the PowerCommander gave more flexibility with the fuel mapping ...
GoFaster is offline
post #8 of 32 Old 07-12-2005, 04:25 PM
There is no doubt about it, the PC is the most efficient way to tune fuel. Each time you want to make an adjustment you would have to pull the ECU and take it apart pull the chip, reburn the chip and install, not to mention rewrite teh code.
post #9 of 32 Old 07-12-2005, 04:30 PM
Snoop, the race kit ecu is flashable in the box on the bike with the PC software, kind of like the PCIII, but unlike the PCIII, the race kit goodies are like $2k
Stop Whining!!!
post #10 of 32 Old 07-12-2005, 04:48 PM
10rmotor's Avatar
Um, no. Ecus nowadays don't use chips that are removeable. You re-flash them, either by sending them away to someone who knows how and has the correct hardware, or by yourself, using a pc (not a power commander) or something like a teka tool.
I've been trying to talk to Mark at FactoryPro for some time now and get no answer, not even a machine, to answer this question. If anyone does, please post the answer. I did see Tberds comments about what he "did" but will believe it when I see it.
10rmotor is offline
Arata slipon map needed jrsjkd Performance and Tech 14 06-23-2005 04:57 PM
ECU resolution BNninja The ZX-10R 24 05-20-2005 07:19 AM
WTB Stock parts '04ZX10R BackMarker Wanted: Buy or Trade 9 11-03-2004 09:51 PM
Stock ECU, tuning? BeepeR The ZX-10R 2 10-05-2004 06:06 PM
Muzzy slip on PCIIIusb map miykl The ZX-10R 5 05-30-2004 05:16 PM
