Gen 4: 2011-2015 How to bypass speed sensors (kit ecu) - Kawasaki ZX-10R.net
post #1 of 11 Old 05-17-2012, 06:14 AM Thread Starter
Hello, i need input from the experts.
I have a gen4 in a race car. I have the race kit ecu and harness. We are not aloved to use wheel speed sensors, so I need to bypass them. I have unplugged them, but I get error code 24 and 27 and the meter is flashing while I'm driving on track.
I have tried to have them in aswell, but I get the same error messages as they do not get the input as expected.
Any suggestions how to fix this?
sunbernt is offline
post #2 of 11 Old 05-17-2012, 06:17 AM
Gen2 Ripper
neverendingmods's Avatar
Will likely need to send ecu to to guhl to have codes turned off inside it. Plus they can do a lot more for you too to make 20hp more.
neverendingmods is offline
post #3 of 11 Old 05-17-2012, 06:19 AM
Gen2 Ripper
Woops. Not sure about kit ecu but should be in there. You have the tuning cable and software?
post #4 of 11 Old 05-17-2012, 09:15 AM
tampazx's Avatar
Pictures!!!!
tampazx is offline
post #5 of 11 Old 05-17-2012, 10:15 AM
dsabat's Avatar
First, I'd call Don Guhl - 717 618 4212. No flashing, no sensors. But he may not be able to do this immediately, I doubt he has encountered this need before. But he might, I don't know, call him.
Or, ignore the flashing dash. You'll get used to it.
Or, try to convince the race officials that you will not use traction control. Leave your sensors in place. Turn traction control off every time you start the car.
And: post pics please. Is this an open wheel, asphalt car? What weight?
Dean
dsabat is offline
post #6 of 11 Old 05-17-2012, 12:55 PM Thread Starter
I have the software and tuning cable, but can't find a setting in the software to disable the sensors.
I will upload pictures later, do not have them here atm.
sunbernt is offline
post #7 of 11 Old 05-17-2012, 01:08 PM
Shift_Nashville's Avatar
Pics or it doesn't exist...
Sounds awesome, we're all waiting!
Shift_Nashville is offline
post #8 of 11 Old 05-17-2012, 02:57 PM Thread Starter
Dean
Not sure if guhl knows the kit ecu, but it might be worth a try. I am consirdering putting them both on the rear axl so they read the same. That would take out the tracking control.... But I rather bypass them, so I do not have to take care of them anymore.
The car is for track racing and rally cross. Have a look at www.shortcar.com.
sunbernt is offline
post #9 of 11 Old 05-17-2012, 04:35 PM
Wow, that's frickin awesome! How much does one of those cost to build?
post #10 of 11 Old 05-17-2012, 04:45 PM
Btrain87's Avatar
sounds awesome! pics!
Btrain87 is offline
04 ZX 10 tip over sensor Bypass Willie Lee II Performance and Tech 5 12-01-2011 10:44 PM
How do i bypass kickstand switch ? STREETLEVEL The ZX-10R 18 11-07-2010 10:24 AM
KISS ignition bypass bostromus The ZX-10R 2 06-07-2010 06:30 PM
How can I bypass the Tip / Vehicle Down Sensor imdrax Welcome Newbies! 1 05-03-2010 08:35 AM
zx-10r ignition bypass how to? brandon1566 Performance and Tech 10 10-04-2009 01:33 PM
