How bad is popping on decel? - Kawasaki ZX-10R.net
post #1 of 7 Old 05-14-2011, 03:53 PM Thread Starter
ikaika's Avatar
I am looking at getting a reflash and/or PCV becuase of my constant popping on decel. I was just curious, does anyone know how detrimental to my engine is it if I leave the bike as is? Other than the popping, she runs like a champ. It has been running like this for the last 2 years.
Custom FE/CA taillight/TechSpec/Driven D-Axis gas cap/Cox Racing/Champs frame-fork-swingarm sliders/Puig ZRacing/Titax/Woodcraft-Attack case covers/SME rear axle block sliders/Misc carbon fiber/ZG Latigo/HID's/M4 Street Slayer/BMC/XTre/EK 520 MVXZ/+4 Drive Sys/SpeedoHealer/HEL 'Stealth'-Motul RBF600-Galfer pads/KyleRacing damper/Rifleman's/Ivans b/o plates/Q3's/Motul 300v/Engine Ice/Shorai
http://www.maresohana.com/ktrsd
ikaika is offline
post #2 of 7 Old 05-14-2011, 04:29 PM
Search the site and do some reading - pulling fuel at 0 percent and reducing at the very low levels (2 and 5 percent, for Dynojet) somewhat should solve it. It did for me and a number of others.
c3hp0 is offline
post #3 of 7 Old 05-14-2011, 07:23 PM
SkyDork's Avatar
It won't hurt anything. It's after-firing in the exhaust pipe because fresh air is being injected to burn unspent fuel for emissions purposes. Less restrictive pipes make the issue worse than with the stock exhaust. The only thing that may happen is you'll shorten the life of your muffler packing if you're getting a lot of it and more sustained flames.
A re-flash or tuning is not likely to fix anything. You need to get block off plates and remove the air injection valves and plumbing.
#WordCrimes
SkyDork is offline
post #4 of 7 Old 05-14-2011, 09:58 PM
Sasquatch's Avatar
Oddly enough, that's when mine started popping on decel. It only happens once in a while and it's always at 3k rpm. When it does happen it's quite funny-people look around trying to figure out where the shots came from. I'd rather it not happen at all though.
Have a wheelie nice day!
Winter sucks.
Sasquatch is offline
post #5 of 7 Old 05-14-2011, 10:17 PM
Blitzkrieg
YB Legal's Avatar
block off plates and i have not had any issues.
"There is always time to think about what you want to do,
Until it comes time to start doing what you were meant to do."
Be more concerned with your character than your reputation. Your character is what you really are, while your reputation is merely what others think you are.~unknown~
"The true test of a mans character is how he treats someone, from whom he has nothing to gain"
"It's the things that people don't know about themselves on the inside, that make them afraid"
YB Legal is offline
post #6 of 7 Old 05-15-2011, 02:47 PM
Starbucks Connoisseur
Static IP's Avatar
I miss mine doing that after I insalled a PCIII :(
09' Ice Blended Peppermint Mocha Frappuccino
10' Venti Mocha Latte spilled some of it, was too hot
11' Peppermint Mocha W/Extra Shot of Espresso
12' Eggnog Venti Latte
13' Bagel
14' Standard Drip (since a Venti latte went up 20 cents)
Static IP is offline
post #7 of 7 Old 05-16-2011, 01:39 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
https://www.zx-10r.net/forum/showthread.php?t=79926
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
'08 Loading up on decel SH4DY Performance and Tech 0 09-14-2010 12:04 PM
1st gen popping/backfiring on decel! stealthyninja The ZX-10R 12 05-05-2010 06:09 PM
04 decel popping questions? Help wakenout Performance and Tech 9 05-22-2009 04:29 PM
Popping On Decel/Shooting Flames CurtZX Performance and Tech 31 05-17-2007 11:45 AM
Popping on decel FiX! DustinR Performance and Tech 16 04-06-2005 04:37 AM
