How To: another brake fluid how to - Kawasaki ZX-10R.net
post #1 of 7 Old 03-07-2010, 05:35 PM Thread Starter
edouble's Avatar
This is not a thorough how to. I am only posting some handy tools to do the job that worked well for me with little mess.
Tools ---> I posted links for visual identification of parts only
- Fork Oil Level Gauge by Traxxion Dynamics http://www.traxxion.com/detail-42.aspx
- Performance Tool Bleed-O-Matic
Since I do not plan on ever working on forks again I used my TD fluid level gauge as a way to fill my small rear brake reservoir. This served very useful in filling the front reservoir as well. In reverse it can be used to remove excess brake fluid. Although I do not know if the plastic material will hold up well with brake fluid.
The Bleed-O-Matic tool is extremely useful in bleeding the caliper/MC since it has a magnetic catch tank. With this tool you simply push the plastic hose over the brake bleeder and the catch tank holds excess fluid.
Bleed-O-Matic tool mounted to rear brake disc and rear caliper
Fork Oil Level Gauge by Traxxion Dynamics filled with brake fluid
Pic after brakes were bleed and reservoir filled.
edouble is offline
post #2 of 7 Old 03-07-2010, 05:40 PM
RDLYN13000's Avatar
Images: 38
what kind of brake fluid are you running there?
RDLYN13000 is offline
post #3 of 7 Old 03-07-2010, 05:52 PM
SkyDork's Avatar
:iamwithst Blue brake fluid???
#WordCrimes
SkyDork is offline
post #4 of 7 Old 03-07-2010, 05:55 PM Thread Starter
edouble's Avatar
ATE Super Blue DOT 4
edouble is offline
post #5 of 7 Old 03-07-2010, 06:44 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
Good post and rep comin your way man.....why don't you use the gilles stand adapters you have on the bike?
TMY10ER is offline
post #6 of 7 Old 03-07-2010, 06:50 PM Thread Starter
edouble's Avatar
I have Champs lifters and honestly I bought them for looks
edouble is offline
post #7 of 7 Old 05-16-2010, 02:49 PM
Servo's Eliminatus ;)
hellsrazor's Avatar
Images: 23
I just use my garage shop vac, and suck the brake fluid outta the reservoir and then open the bleeder screws and made an adapter to reduce the vac hose down to fit the bleeder screw and suck the fluid outta the lines and calipers.
Refilled and had a friend add fluid and pump the brake while I bled them.
hellsrazor is offline
Braided brake hoses brake fluid MrT Performance and Tech 6 10-30-2009 09:19 PM
Brake fluid BDB10R Performance and Tech 5 03-29-2008 11:53 AM
brake fluid vinja314 The ZX-10R 10 12-26-2006 10:35 PM
Brake Fluid? 05Ti10 Performance and Tech 15 08-16-2006 07:18 AM
Brake fluid NWZX10 Performance and Tech 6 01-24-2005 04:53 AM
