How-to adjust suspension settings - front - Kawasaki ZX-10R.net
post #1 of 6 Old 05-05-2008, 10:28 AM Thread Starter
edouble's Avatar
For my riding style/weight I have came to the conclusion that my front forks are way to soft. I would like to "harden" the ride up a little and reduce the amount of compression while under hard braking.
I do not like the feeling of the front end falling out from under me when I corner hard on uneven surfaces. P.S. I weight about 175lbs.
1. Do I need to adjust the "Spring Preload Adjuster" (clockwise/counterclockwise and how much?)
2. How many clicks (clockwise/counterclockwise?) for the Rebound Damping Force Adjuster?
3. How many clicks (clockwise/counterclockwise?) for the Compression Damping Force Adjuster
I havent been able to gain 100% confidence in the stock suspension yet and hopefully by making some adjustments I can solve some issues.
edouble is offline
post #2 of 6 Old 05-05-2008, 10:41 AM Thread Starter
edouble's Avatar
BTW I Have an 06 ZX-10R
edouble is offline
post #3 of 6 Old 05-05-2008, 10:51 AM
Big Daddy's Avatar
Images: 38
edouble heres a very simple DIY kind of PDF http://home.comcast.net/~zx-10r.net/...ionSeminar.pdf that you can learn from.
Big Daddy is offline
post #4 of 6 Old 05-05-2008, 11:01 AM Thread Starter
edouble's Avatar
Thanks again BD, you always come thru!!
edouble is offline
post #5 of 6 Old 05-05-2008, 11:04 AM
Big Daddy's Avatar
Images: 38
You can get other riders settings and try them but we are all so diff that its best to learn to setup for YOU and your bike.
take notes and more notes during the process for reference later.
post #6 of 6 Old 05-05-2008, 11:34 AM
norcalzx10r's Avatar
Images: 28
Here is a good link lots of useful info.
http://www.feelthetrack.com/tuning_guide.htm
I would start with setting your rider sag.
Tony
norcalzx10r is offline
06/07 Suspension settings photomike666 Performance and Tech 9 04-14-2008 12:51 AM
Help with suspension settings colinmitchell111 Performance and Tech 15 08-23-2006 03:34 PM
06 Suspension Settings brian0128 Performance and Tech 42 07-28-2006 08:26 AM
Suspension settings again... Mustard Performance and Tech 8 06-17-2005 11:18 AM
Suspension settings that are right on!!! Older Guy Performance and Tech 3 10-15-2004 10:27 PM
