Horn Doesn't Work - Kawasaki ZX-10R.net
post #1 of 5 Old 11-25-2008, 11:36 AM Thread Starter
welds like he has palsy
JP636's Avatar
Horn Doesn't Work
I just replaced my servo and my horn does not work. I'm sure they don't have anything to do with each other, but I was test riding it yesterday due to the servo replacement and that's when I discovered the problem. I did ride it in the rain a lot and then it sat a month. Does the horn have its own fuse? Anyone else have this problem?
Originally Posted by green10 View Post
speakers on a zx10 is like shitting in your bathwater!!!
JP636 is offline
post #2 of 5 Old 11-25-2008, 12:08 PM
Supercharged Mod
Pull the two connectors off the horn, stick a voltmeter between them, and see if there is voltage between the connectors when you press the horn button with the key switched on.
GoFaster is offline
post #3 of 5 Old 11-25-2008, 12:24 PM Thread Starter
JP636's Avatar
I'll have to pick up a voltmeter. I also forgot to mention that the horn works every once in a while. While on the ride yesterday, I first noticed it didn't work. Then it worked and went out intermittently.
JP636 is offline
post #4 of 5 Old 11-25-2008, 12:50 PM
EbonyZX10R's Avatar
Images: 12
doesn't have to be a voltmeter. you can take one of the signal bulb and make a simple tester, connect one wire to positive and one in negative of the horn wires.
Member of The Elite - Growler Group
08 Swingarm,08 SHOCKS,Racefit Growler, PCIII, Gipro w/ Atre, BMC Race Filter, Pazzo Shorty Levers, SATO Frame Sliders, Sportech Windscreen, Seat Cowl, Scopion Alarm, CompWerkes Fender Eliminator, Hybrid SATO rearsets, Nissin Calipers, Galfer SS Lines, EBC HH Brake Pads, Driven 520 Front and Rear Sprockets, Vortex Block Off Plates, RK GB520GWX Gold Chain,Champs Chain Adjusters, SpeedoHeeler. Coming soon-Ohlins TTX and Racetech Front Fork Rebuild Kit
EbonyZX10R is offline
post #5 of 5 Old 11-25-2008, 05:10 PM
Gone Ridin'
twidget's Avatar
Send a message via AIM to twidget Send a message via MSN to twidget Send a message via Yahoo to twidget
There is indeed a (10A--I think) fuse for the horn, but if it is intermittent then it is more likely a loose connector or a bum horn.
That was one of the first items I replaced since I commute on mine every day. The 130db air horn always gets their attention.
twidget is offline
Car horn mod. LOUDER THAN MY CAR 06Neenja Performance and Tech 20 05-23-2008 08:19 PM
Stebel air horn, $20 06Neenja Parts, Gear and Accessories 6 11-19-2007 08:38 AM
Horn upgrade Bradlee_T Pictures and Videos 8 10-26-2007 06:17 AM
nos wiring horn...? hccaamps The ZX-10R 7 05-05-2007 02:48 PM
Now I've got the horn.... Goatozaki Pictures and Videos 15 09-17-2004 01:26 AM
