Hit the Rev Limit and it cut off? - Kawasaki ZX-10R.net
post #1 of 21 Old 05-02-2008, 05:32 PM Thread Starter
jdgun_13's Avatar
Send a message via Yahoo to jdgun_13
Well i was coming back from my tuner and the bike was running amazing and was coming out of a traffic circle and though i would unleash the Fury, well as i hit the rev limiter in 1st since it spooled up way faster than before the bike dies on me, i rty and restart while costing but NO EFFECT.
come to stop and turn off the ignition and then back on she runs like nothing happened.
Is this typical?
jdgun_13 is offline
post #2 of 21 Old 05-02-2008, 05:43 PM
Images: 26
Is this typical?
THAT SUCKS I HOPE THIS IS NOT RIGHT ,
anthonyzx10r2008 is offline
post #3 of 21 Old 05-02-2008, 05:48 PM
axo250's Avatar
Send a message via AIM to axo250
I've hit the rev limiter a couple different times and it has never died after that. Sounds wierd to me. Not sure what could have caused it though.
"Besides, my ZX-10R eats GSX-Rs for breakfast." -- SportRider Magazine Article
axo250 is offline
post #4 of 21 Old 05-02-2008, 05:49 PM
JaydeeZX10's Avatar
Images: 7
Send a message via AIM to JaydeeZX10 Send a message via Yahoo to JaydeeZX10
Def a weird thing to have happen.
2007 ZX10
JaydeeZX10 is offline
post #5 of 21 Old 05-02-2008, 06:06 PM
Check your connections. I'm guessing you have a PCIII, so look at the ground and the battery cables to make sure they aren't loose. I had that issue with both of my bikes. On the 10R, my battery cable where the ground from the PCIII goes was loose so it would cut out. Basically just check all of the connectors. It's not normal for it to cut out.
04 ZX-10R - track
02 RC-51 - street
Mtn Z is offline
post #6 of 21 Old 05-02-2008, 06:14 PM Thread Starter
jdgun_13's Avatar
will do as i am running a PCIII and an ivans TRE...hoping it does not have anything to do with either one or the fact i am running a 06/07 gauge cluster on the 04 bike.
going to go thru the wire harness of where we hooked up the pick-up as well, maybe just a loose wire.
jdgun_13 is offline
post #7 of 21 Old 05-02-2008, 07:11 PM
Yeah, as much plugging and unplugging you have had to do with the cluster, PCIII, and TRE, it wouldn't surprise if something was overlooked or just came loose. Good luck!
04 ZX-10R - track
02 RC-51 - street
Mtn Z is offline
post #8 of 21 Old 05-02-2008, 07:27 PM
inappropriate
hesaves0211's Avatar
Images: 67
perhaps an ignition problem?
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #9 of 21 Old 05-02-2008, 09:14 PM
bkkninja's Avatar
something wrong definite.
I bounce off the limiter all the time on track. It just feels like a missfire until the rev drops a bit then all back to niormal.
Never had a complete cut off.
BKK
bkkninja is offline
post #10 of 21 Old 05-03-2008, 01:45 AM
Images: 26
thats why we have warranty
Fix the speedo readout limit thrill Performance and Tech 12 03-26-2007 03:44 PM
80KPH Speed Limit. IITravel Pictures and Videos 1 11-13-2006 11:02 AM
12k rpm limit on pc3 maps ? fordfasterr Performance and Tech 14 10-26-2006 09:02 AM
Timing retard to limit to 186 mph or not? El Diablo Performance and Tech 21 04-12-2006 02:04 PM
speed limit on tires grego10r The ZX-10R 15 05-17-2005 05:40 PM
