high speed wheel bearings - Kawasaki ZX-10R.net
post #1 of 10 Old 03-25-2006, 07:46 AM Thread Starter
ballsup's Avatar
Does anyone know where I can get them? Not the ceramic bearings. They are to much maint.
ballsup is offline
post #2 of 10 Old 03-25-2006, 10:15 AM
ss
bearing works ask for Dean
888 773 8872
04ZX10 is offline
post #3 of 10 Old 03-25-2006, 11:45 AM
MIA Post Whore
miykl's Avatar
Yup... dem are the ones I have. Ask Robin how much easier they spun. He was in shock.
2011 Ninja 1K street
2004 636 track
miykl is offline
post #4 of 10 Old 03-25-2006, 11:59 AM
Supercharged Mod
There is no need to specify any unusual speed rating for motorcycle wheel bearings.
Motorcycles use standard off-the-shelf deep groove ball bearings as wheel bearings. The standard versions of those bearings have speed ratings that exceed the highest possible wheel rotation speed by a huge margin.
Any industrial supply place can get equivalent deep-groove ball bearings, in any seal configuration you'd like. Personally, in the interest of longevity, I stick with the standard DD contact-type rubber seals.
This has been posted and extensively discussed before.
GoFaster is offline
post #5 of 10 Old 03-25-2006, 12:13 PM
MIA Post Whore
miykl's Avatar
Balls is wanting the low resistance seal type. He's still chasing after Pesky's R1.
2004 636 track
miykl is offline
post #6 of 10 Old 03-25-2006, 12:14 PM
do you have front and rear ? and how much $$ ? can u feel the difference?
oneradten is offline
post #7 of 10 Old 03-25-2006, 12:45 PM
P.Garvin is offline
post #8 of 10 Old 03-25-2006, 02:54 PM
MIA Post Whore
miykl's Avatar
I have both. spinning th estock bearing and the low resistance one by hand (out of the wheel) there is a huge difference. Spinning the wheel on the bike there is less of a difference. Actual real world results... wasn't enough to make up for my gut.
I'd only do it again if I needed bearings or if you're at the cutting edge of the bikes performance and need a little more.
don't remeber cost. seams like it was in the $50 range. I saw a post that they went up though.
2004 636 track
miykl is offline
post #9 of 10 Old 03-25-2006, 06:04 PM
phastone's Avatar
Haven't installed them yet. Waiting on tire change. With shipping, mine ran me $78 from BearingWorks.
phastone is offline
post #10 of 10 Old 03-25-2006, 07:40 PM
[=lkl
mine cost the same , havent installed them yet
04ZX10 is offline
High speed wheelies, Lift and Downforce lenshead The ZX-10R 19 07-01-2005 04:17 PM
1st high speed run on the 10 TTLex The ZX-10R 58 06-22-2005 05:41 PM
Wheel Bearings Problems? zixxer The ZX-10R 19 06-06-2005 03:08 PM
Wheel bearings 1killer1liter Performance and Tech 4 04-28-2005 05:47 PM
Warning About BST Carbon Fiber Wheels........ SP8 The ZX-10R 20 01-18-2005 08:28 AM
