High speed front brake vibration issue - Kawasaki ZX-10R.net
post #1 of 31 Old 09-26-2010, 07:33 PM Thread Starter
STurner's Avatar
You all are the experts, so I thought I would ask before taking to the dealer or shop.
I get rapid vibration in the front brake lever when braking at freeway speeds, 55mph or higher - particularly when I brake hard. It used to be only higher speeds (over 65), so I think it's progressively worse.
Cars will do this when they need new rotors, which is what I think it might be. I don't believe this is tire balance, since this is the second set of tires I've noticed this on.
The '08 is still under warranty but I don't think they cover rotors at 11,000 miles - or will they?
Thanks in advance -
STurner is offline
post #2 of 31 Old 09-26-2010, 07:50 PM
zx10Duran's Avatar
thought it was unlimited miles 12 months?
zx10Duran is offline
post #3 of 31 Old 09-26-2010, 07:55 PM
TENN10's Avatar
Images: 145
Even so, I doubt they will cover the rotors.
TENN10 is offline
post #4 of 31 Old 09-26-2010, 07:57 PM
RDLYN13000's Avatar
Images: 38
Check your head bearing!
RDLYN13000 is offline
post #5 of 31 Old 09-26-2010, 07:59 PM
TENN10's Avatar
Images: 145
Thanks in advance -
Your rotors may be warped, but I would pull the calipers off and clean the pistons and guide pins really good first.
TENN10 is offline
post #6 of 31 Old 09-26-2010, 08:07 PM Thread Starter
STurner's Avatar
I have an extended warranty - 3 years right now, and the dealer is offering another 4 on top of the (7 years) for another $600. I don't have $600 to drop but that shows how reliable these toys are..
STurner is offline
post #7 of 31 Old 09-26-2010, 08:32 PM
WLTD's Avatar
I would say balance of the tires but if its when you brake i'd say rotors but i've got so many miles on my stock rotors so I dont know what to say. You go through a lot of hot and cold/wet cycles? ride in ran maybe?
head bearing is a poss BUT if its a violent shake i'd rule that one out especially at 11k on a 08. Mine was fine on my 05 with 23k only reason why it was bad was due to too much torque from my scotts damper being put on. so i'll go back to saying balance...I had this same problem recently with a retard shop!
WLTD is offline
post #8 of 31 Old 09-26-2010, 08:45 PM Thread Starter
STurner's Avatar
Thanks for all the advice - I think I'll get the front wheel re-balanced first. If that doesn't solve it, call the dealer and see if warped rotors are covered and go from there.
STurner is offline
post #9 of 31 Old 09-28-2010, 11:10 PM
Brake pad build up can cause a similar symptom as warped rotors. The residue doesn't build up perfectly even, and also will slip-grab-slip-grab causing a pulsing/vibration - a similar symptom of if the pads are just glazed over which is possible.
If the rotors are not warped then new pads, brake cleaner, and a Scotch-brite pad would be step one, and bead blasting the rotors would be great, if possible.
Headstock bearings, as mentioned, are also another source of mysterious vibration under a load.
Cocky Rooster is offline
post #10 of 31 Old 09-28-2010, 11:59 PM
cardeea's Avatar
Tire/ wheel balance.
cardeea is offline
Wheel bearings not the vibration issue! Ninjamaster Performance and Tech 1 07-15-2008 05:39 PM
05 front brake issue (636 mc) wicked Performance and Tech 3 05-23-2008 10:41 AM
Front Brake issue hotfocuson18s The ZX-10R 12 05-29-2007 06:52 PM
Anyone see the Sept/Oct issue of R&T Speed? ZX10 Guy The ZX-10R 17 10-03-2005 02:20 AM
1st high speed run on the 10 TTLex The ZX-10R 58 06-22-2005 06:41 PM
