High performance in a can - Kawasaki ZX-10R.net
post #1 of 56 Old 01-16-2005, 06:39 PM Thread Starter
Post Whore
Older Guy's Avatar
Guys:
I have been using this stuff for years...started in airplanes and approved by the FAA.
http://www.microlon.com/detail.asp?product_id=ILM08
$29.95
Put a can (8 oz) in the 10 this afternoon and HOLY SH*T, it now really goes like HELL. You put 2 oz in the gas tank...
Went off with some Gixxers and blew them off so bad, they were shaking their heads when they pulled up at the next signal...
Older Guy is offline
post #2 of 56 Old 01-16-2005, 07:13 PM
rdandy5875's Avatar
SO you put 2 oz in the gas and 8 oz in the motor?
Does it make any difference with it just in the motor? And not the tank.
I've been looking for something to stabilize the oil a little.
rdandy5875 is offline
post #3 of 56 Old 01-16-2005, 07:17 PM Thread Starter
Post Whore
Older Guy's Avatar
No, dude...2 oz in the gas tank and the remaining 6 oz in the oil...total is 8 oz.
This stuff does NOT stabilize the oil...it is not a friction reducer, per se...it microscopicly fills in pores in the metal in your engine...
I'll give you an example...I had an old Nissan pick up and the synchros were shot in first to second gear...I put a can of this stuff in the transmission (the transmission additive) and after about an hour of running, the tranny shifted like butter...made an incredible difference...
post #4 of 56 Old 01-16-2005, 07:26 PM
rdandy5875's Avatar
ok 6oz in the motor.
Like I siad I've been looking for an additive for the oil. A friend of mine puts that super lube stuff you see in the autostores with the little gear setup, with regular oil on the opposite side. I just haven't heard of anyone else using it in their bikes, so I'm not putting it in mine.
But this stuff seems more in the right direction. Thanks
post #5 of 56 Old 01-16-2005, 07:41 PM
crispin's Avatar
Send a message via AIM to crispin
ummm..
I don't know.
Surprised at your post.
You were faster than other bikes just just an oil and gas additive?
Why wouldn't ever bike have this stuff?
ya ya ya...
crispin is offline
post #6 of 56 Old 01-16-2005, 07:43 PM Thread Starter
Post Whore
Older Guy's Avatar
I was faster before I added this stuff, but this just made it better...
post #7 of 56 Old 01-16-2005, 07:44 PM
rdandy5875's Avatar
i bet it improved shifting and clutch too????
post #8 of 56 Old 01-16-2005, 07:46 PM Thread Starter
Post Whore
Older Guy's Avatar
That is the reason I put it in...the 10 doesn't shift as well as a Zuke...does now...
post #9 of 56 Old 01-16-2005, 07:59 PM
rdandy5875's Avatar
have you tried heir other stuff that's $55 a can? says you only need it once, but lot more expensive.
post #10 of 56 Old 01-16-2005, 08:01 PM Thread Starter
Post Whore
Older Guy's Avatar
I called them up and that stuff isn't necessary for our usage....
To High mount or not to High mount BNninja Performance and Tech 4 10-25-2004 01:59 AM
FS Ti Hindle High mount SVTxtreme Parts, Gear and Accessories 8 10-24-2004 04:01 AM
Thinking about Devil High Mount???? youngballer The ZX-10R 5 07-14-2004 09:46 PM
Let's See That Performance Wish List......... SP8 The ZX-10R 22 05-29-2004 07:27 AM
Performance Bikes.. CDRacingZX6R The ZX-10R 4 05-01-2004 08:42 AM
