high compression pistons - Kawasaki ZX-10R.net
post #1 of 11 Old 04-11-2011, 01:43 AM Thread Starter
copperelite's Avatar
Send a message via Skype™ to copperelite
ok so i have to rebuild my engine, im doing the race intake and thin head gasket. my question is would the 13:5:1 pistons make it to much compression for a daily driver?
copperelite is offline
post #2 of 11 Old 04-11-2011, 08:01 AM
You will get a couple different answers and both could be right.
If you want piece of mind and a few extra hp ceramic coat the piston tops and cc
http://www.calicocoatings.com
Fast turn around and not expensive.
ricksgsxr is offline
post #3 of 11 Old 04-11-2011, 06:01 PM
Post Whore
1killer1liter's Avatar
Images: 11
Stock gen 1 and gen 2 compression is 12.7. With the thin head gasket its 13.2 to 13.45. With the 13.5 pistons and thin gasket, it would be 14 to 14.25. Too much for the street unless you can afford 110+ octane race fuel.
1killer1liter is offline
post #4 of 11 Old 04-12-2011, 03:48 AM
bugman53's Avatar
My 10 is at 14.1/1 and it barley gets by on 93. I did do a couple things to the combustion chambers, smoothing off all sharp edges, a little polishing. but 13.5 is my upper limit when i build street motors for customers.
bugman53 is offline
post #5 of 11 Old 04-12-2011, 04:22 AM Thread Starter
yea i can only get 91 octane out here in phoenix... any of you guys know where i can get ceramic motor/tranny bearings
post #6 of 11 Old 04-12-2011, 09:22 AM
Gen 5 Now!!
08zx10rny's Avatar
yes either this site:
http://worldwidebearings.com/ceramic.htm
or
http://www.orientexpress.com/Kawasak...aring+Kit.html
08zx10rny is offline
post #7 of 11 Old 04-13-2011, 02:34 AM
tasos's Avatar
Hey man, do you know if Kawi makes race springs for the 08?
Also where i should find 08Ti retainers? Are they the same with 04-07?
Thanks
tasos is offline
post #8 of 11 Old 04-13-2011, 09:58 AM
Gen 5 Now!!
08zx10rny's Avatar
no kawi does not make race springs for the 08. the 04-07 retainers are not the same either. i was going to send my head to jay over at ape racing so they can take a look. they were going to custom make me a set but decide on trying the 2011 springs and retainers. they are good for over 14000 rpm so those will be fine. havent gotten around to doing it yet. trying to sell my 08 je pistons (std size) and buy 2mm over je pistons because my spare motor has a cylinder wall wiped out.
Thanks
post #9 of 11 Old 04-14-2011, 12:58 AM
tasos's Avatar
Thanks. Do the 2011 springs and retainers fit in the 08 for sure?
Has anybody tested it before?
tasos is offline
post #10 of 11 Old 04-14-2011, 08:49 AM
Gen 5 Now!!
08zx10rny's Avatar
im pretty sure they will. gonna try working on it in the next couple of days. ill keep u posted.
high speed compression dnb General Motorcycle Discussions 5 10-08-2009 03:34 PM
high speed compression dnb The ZX-10R 4 08-12-2008 10:48 AM
CR250...Ported/ high compression for sale Sands Parts, Gear and Accessories 1 02-29-2008 06:34 AM
Hi Compression Pistons anyone??? speedtechnz Performance and Tech 5 02-26-2008 01:27 AM
2003 Ported/High compression CR250 Sands Parts, Gear and Accessories 1 11-13-2006 04:53 AM
