high comp piston and lightened crank??? - Kawasaki ZX-10R.net
post #1 of 10 Old 12-18-2008, 07:47 PM Thread Starter
Thumbs up high comp piston and lightened crank???
Hello, im a newbee to this forum and i'm a proud owner of two zx10's (04 race, 06 street)
My mods to my 04 include full muzzy exhaust, powercommander, and flies removed.
My motor is being torn down for transmission issues(2nd and third gear dogs rounded). Therefore, its going to get the transmission undercut and while i'm in their i'll be doing a thin head gasket and 13.5 to 1 pistons and lightened crank.
Baseline numbers on a stingy dynojet 250 i are as follows:
Stock 138 hp
Stock with hmf slip on only 142.3
Now it has muzzy exhaust and the rest of the above mentioned mods.
Question: Are there any issues with running kawasakis thinnest headgasket with 13.5 pistons?
What should my cam timing be set at? (stock cams)
Does anyone have a lightened crank in there bike and if so what are your impressions?
Thanks
mralbuquerque is offline
post #2 of 10 Old 12-18-2008, 08:23 PM
busa41's Avatar
I hope whoever is doing this expensive work for you also can answer your questions.
busa41 is offline
post #3 of 10 Old 12-18-2008, 11:49 PM
ducatiryder89's Avatar
Images: 21
Well for starters what size headgasket 55 I think is there thinest? Secondly no one but you and the one that is building this bike should answer the question "is ok to run thin head gasket with 13.5 to 1 pistons?". How you can tell is by measuring the squish amount. Also remember you will be running close to 14:1 compression if you can use a thin head gasket and kiss pump goodbye. Next there is no set magical Cam Timing numbers. Really its trial and error. Does your motor like more overlap or less overlap and where do you want your power to come in at. All cam timing does is move your powerband just FYI. With those pistons I would highly recommend doing some headwork and replacing the intake cam with a Kawi Kit Intake cam at least. Kawi's Race Manual gives you a very good inital start point. But sounds like it will be a beast when its done. Good luck.
2005 ZX10R Track Bike With Way To Much Sh*t On It!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ducatiryder89 is offline
post #4 of 10 Old 12-19-2008, 06:33 AM
Speed Freak
garth285's Avatar
you will be fine with that set up. I have a lightened crank and I'm running 13.5:1 pistons and I have my head decked .0015"
garth285 is offline
post #5 of 10 Old 12-19-2008, 04:40 PM Thread Starter
What do you mean kissing the pump goodbye?
thanks
Garth are you running pump gas and are you using a thin headgasket as well with the .015 shaved head?
post #6 of 10 Old 12-19-2008, 04:51 PM
Vince10R's Avatar
I got a good complete trans with 4 miles on it if you need one.
Vince10R is offline
post #7 of 10 Old 12-19-2008, 10:33 PM Thread Starter
I would be interested for $150 plus shipping and paypal costs. Let me know
Thanks
post #8 of 10 Old 12-20-2008, 03:24 PM
Vince10R's Avatar
Its yours if you want it for $150 plus shipping and paypal send me your zip so I can quote the shipping
Vince10R is offline
post #9 of 10 Old 12-20-2008, 05:31 PM Thread Starter
Send me some pics to my email. Give me your phone # so we can talk about it.
[email protected]
post #10 of 10 Old 12-20-2008, 05:31 PM Thread Starter
Give me your phone # so we can talk about it. Also send some pics to my email.
[email protected]
Piston kit price zixxer Vendors deals 1 06-23-2008 10:25 AM
1999 piston pins jrc0210 ZX-9R Discussion 7 04-03-2008 05:52 PM
Piston rings appocalypse Vendors deals 0 11-13-2007 08:22 AM
Piston Shot Thru The Arm! litrejunkie Pictures and Videos 8 04-30-2006 12:53 PM
high comp gasket install??? on1whl Performance and Tech 2 02-28-2005 07:49 AM
