high comp gasket install??? - Kawasaki ZX-10R.net
post #1 of 3 Old 02-28-2005, 03:10 AM Thread Starter
I am planning on installing the high comp gasket and having the cams degreed...
Anyone have time to give me an easy way to change the gasket??? Is dropping the motor a must??? Any other tips will be appreciated....
Thanks
[email protected]
on1whl is offline
post #2 of 3 Old 02-28-2005, 07:31 AM
crispin's Avatar
Send a message via AIM to crispin
Thanks
[email protected]
I found the easiest method for me was to drop it off at the shop and let the pros handle it.
I love my bike too much to fugg it up by trying to work on it myself.
ya ya ya...
crispin is offline
post #3 of 3 Old 02-28-2005, 07:49 AM
There is a thread called Ivan's Performance ZX10,
that is where Ivan says you must drop the engine to properly degree the cams unless you are leaving them stock which Ivan said is a waste. Then you can also read the settings he recommends to set the cams to.
BNninja is offline
SpeedoHealer Install step by step w/pics>> El Diablo Performance and Tech 80 04-24-2008 12:53 PM
K&N Air Filter Install w/Pics bchild Performance and Tech 47 02-16-2005 04:17 PM
Sato Rearset Install w/pics>>> El Diablo Performance and Tech 80 01-21-2005 07:27 AM
SpeedoHealer Install step by step w/pics>> El Diablo How To... 2 01-10-2005 02:35 PM
To High mount or not to High mount BNninja Performance and Tech 4 10-25-2004 01:59 AM
