HID's quit working - Kawasaki ZX-10R.net
post #1 of 5 Old 08-06-2006, 08:32 PM Thread Starter
HID's quit working
I installed some Purevision HIDs on my 10 about a month ago and they were great. On friday my buddy and I pulled up to a gas station and said "your headlight just went out about a block ago". We started checking the fuses, connections, etc and they just came back on. Went for a ride today and no low beam whatsoever. Again started checking fuses, connections, bulb, and nothing looked bad and nothing worked. When I got home I got the meter out and started tracing down the wires. I have power up to the low beam ballast but nothing coming out of it. The high beams work fine.
Has anyone had any problems like this? I've never had HIDs on anything before so I don't know what to look for. I e-mailed the e-bay store I bought them from but have heard nothing back yet.
speedfreak is offline
post #2 of 5 Old 08-06-2006, 09:11 PM
colinmitchell111's Avatar
Send a message via AIM to colinmitchell111
Yikes.. I have the same kit and no problems here. Hope you figure it out!
colinmitchell111 is offline
post #3 of 5 Old 08-06-2006, 09:25 PM
bonz's Avatar
Similar problem, I have power to the ballasts but nothing coming out to either high or low. Bought mine off e-bay too, guy sent me a new wiring harness to try but nothing. Would like to find someone who can look at the ballasts???
bonz is offline
post #4 of 5 Old 08-06-2006, 11:12 PM
zootzoot35's Avatar
Wtf?
I went with the Xetronic kit! No prob's so far! Do you have both lights with the hid set up! I only did one! While I was on the phone with XETRONIC,they did tell me that if I went with the low/high beam that I may need to get a larger fuse and a relay!
zootzoot35 is offline
post #5 of 5 Old 08-06-2006, 11:33 PM Thread Starter
Yeah, I have both sides fused (30 amp) and a relay for each ballast. I wanted to be able to safely use my hi/low beams without overloading my wiring. Like I said fuses are fine and relays are working, so nothing wrong with the wiring.
HID's ontada2 The ZX-10R 23 02-20-2007 10:57 AM
Just Installed HID's.. colinmitchell111 The ZX-10R 14 07-11-2006 09:39 PM
***quit Crashin People!!!*** hillcountry10r The ZX-10R 35 05-28-2006 02:25 AM
Where i got my HID's RickRoush03 The ZX-10R 1 11-23-2005 11:45 PM
