Help with a warning - Kawasaki ZX-10R.net
post #1 of 11 Old 03-17-2008, 04:30 AM Thread Starter
Help with a warning
Can anybody please tell me what FL or FI means when it flashes n the dash of an 06 10 ?
thanks
Jimsmowen is offline
post #2 of 11 Old 03-17-2008, 05:40 AM
bkkninja's Avatar
thanks
When FI fashes whilst engine is running. This indicates a fault with the Fuel Injection system.
bkkninja is offline
post #3 of 11 Old 03-17-2008, 05:41 AM Thread Starter
ok wait it just so happens it was almost inline with the bike running out of fuel, possible they are related ??
post #4 of 11 Old 03-17-2008, 06:28 AM
bkkninja's Avatar
That would be your fuel light coming on?
bkkninja is offline
post #5 of 11 Old 03-17-2008, 06:36 AM Thread Starter
ok I give u the full story. it was in a crash, i changed the oil and never ran it for like 2 months. Finally ran it tonight, it starts fine and runs better than ever (before it would die the second i touched throttle) now its fine with that, but this FI light flashes and red light flashes also oil light flashing. But I had the rear stand on, so took it off and oil light goes out. Then it runs out of fuel, total running time since start of day was probably only 2 minutes. I go get fuel fill it up and start it up, seems to be running perfectly other than no cans being on it. But the FI light wont budge? It just flashes, but bike seems to rev fine...
possible its sucked a bit of grit out of the bottom of the tank since i ran it dry? or do the pumps always suck from the dead bottom ?
post #6 of 11 Old 03-17-2008, 06:47 AM
bkkninja's Avatar
Ok Therefore you have a fault somewhere on your engine.
a. Get hold of a manual and understand the flash code.
b. Take it to a dealer and let them sort it.
bkkninja is offline
post #7 of 11 Old 03-17-2008, 06:48 AM Thread Starter
by flash code im assuming u mean the order the red light flashes in?
thanks
post #8 of 11 Old 03-17-2008, 06:53 AM
silversv1k's Avatar
Images: 44
thanks
yes...
silversv1k is offline
post #9 of 11 Old 03-17-2008, 09:31 AM
bkkninja's Avatar
thanks
Do you have a manual? U can download it off this forum.
You will need to read the flashes and that gives u a code. If memory serves me right. it starts with a long flash to give u the first digit and then followed by short flashes to give u the second digit. for example code 24. Flash as Long Long = 2 short short short short = 4.
You can double check this in manual.
Good luck and let us know what code u got.
bkkninja is offline
post #10 of 11 Old 03-17-2008, 11:47 AM
themightymezzo's Avatar
With a manual it will also help you diagnose other problems you have as well as any other work you may want to do. IMO always the best investment bike related other than good gear.
themightymezzo is offline
Beer Warning Alien10 The Funny Pages 4 10-04-2007 11:27 AM
Important Warning gpz1100 The Funny Pages 1 06-10-2007 11:32 AM
Police Warning Afterburner The Out House 9 02-18-2006 09:41 AM
off with a warning..... whew JodyH The Out House 13 11-07-2005 09:46 AM
