Gen 1: 2004-2005 Help with tre - Kawasaki ZX-10R.net
post #1 of 4 Old 03-26-2011, 01:57 PM Thread Starter
1808a's Avatar
Help with tre
Whats up fellas wanted to ask if any body can help me on guiding me on how
to install Ivans TRE on a 05 10r i recently bought it from a member here but
he no longer has the instructions..if any body can post a pic where ir plugs
into or any help will be much appreciated
1808a is offline
post #2 of 4 Old 03-26-2011, 02:12 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
The white plug on the left side of the airbox (front left between the larger gray plugs and the hose)....nevermind the tube that's circled in the pic...that's for the block off plate alternative. there are only 2 white plugs like this and the other is at the back of the airbox and is used for the power commander.
TMY10ER is offline
post #3 of 4 Old 03-26-2011, 03:53 PM
PatrickG's Avatar
Images: 15
Try this link it has instructions but no pictures
http://www.schnitzracingstore.com/ca...prodid=4857669
PatrickG is offline
post #4 of 4 Old 03-28-2011, 01:39 AM
tasos's Avatar
Ivan's TRE should be installed on the green connector. (lower left below the fuel rails in TMY10ER's pics).
Remove the green w/red stripe and black wires from the green connectors, hook up the TRE. Doesn't matter which one is where. It's a bit PITA
tasos is offline
