Help with suspension settings - Kawasaki ZX-10R.net
post #1 of 16 Old 08-22-2006, 02:18 PM Thread Starter
colinmitchell111's Avatar
Send a message via AIM to colinmitchell111
Well after searching and reading about suspension settings, I want to adjust mine for better grip. The only problem I have never messed with it and I have no clue how. I dont want to mess anything up or make it worse. I am an agressive rider on the street and like to hit all he twisties arround here so I want to maximize that. I weigh 230lbs in leathers.. I am also getting ready to put a 190/55 on if that makes any difference. Thanks for any advice..
colinmitchell111 is offline
post #2 of 16 Old 08-22-2006, 02:33 PM
Supercharged Mod
1. Stay with the 190/50 rear tire size. Put on new tires before mucking around with suspension at all.
2. For street riding, adjust front preload so as to achieve 35mm rider-aboard sag, adjust rear preload to achieve 30mm rider-aboard sag. For track riding, take 5mm off both of those. Keep in mind that this is only a starting point.
3. Set the front ride height to give the most neutral turn-in response. If you have to hold the bike down in a corner (and you are hanging-off in the corner), you need to lower the front ride height by sliding the forks up in the triple clamps. 3~5mm lowering is not uncommon to get it to feel right. Don't change ride height by more than that. It is also possible to do this by raising the rear rather than lowering the front - the good thing is that a higher bike has more cornering clearance - the bad thing is that a higher bike has a higher center of gravity and will want to wheelie more, which is fine for stunting but not for getting the power to the ground.
4. Damping settings have to be done more-or-less by feel.
GoFaster is offline
post #3 of 16 Old 08-22-2006, 02:53 PM
lavudyar's Avatar
Send a message via Skype™ to lavudyar
Could not disagree more - finding a solid all around setup for your suspension is the single most important handling solution available. You can over-ride or out-ride questionable tires but even the best road or race rubber can't fix a bad suspension setup (and many times will make it worse)!
Set your sag, set all your adjusters in the middle of the range for a starting point and then go here:
http://www.sportrider.com/tech/suspension/
for a great suspension setup primer. It's in plain English so we can follow along.
lavudyar is offline
post #4 of 16 Old 08-22-2006, 03:21 PM
for comp/damper adjustment, why not go with the stock setup as starting point. at least you know the weight it is setup for. you can then go stiffer or softer depend on your weight.
nobody is offline
post #5 of 16 Old 08-22-2006, 05:50 PM
lavudyar's Avatar
There is no such thing as a 'stock' setup. The suspension parts come off the assembly line in no particular state of tune and are not changed until you do it yourself (my fork comp settings were all the way hard on the left and middle click on the right when I picked up my bike - and my RC51 was even worse).
Now, some dealerships will set the adjusters to the middle but they are few and far between and how would you know? The only way to be sure the suspension is correct is to set it yourself.
lavudyar is offline
post #6 of 16 Old 08-22-2006, 10:22 PM
check the manual lately? it's in there stock setup for 150lb.
nobody is offline
post #7 of 16 Old 08-22-2006, 11:00 PM
lavudyar's Avatar
I remember seeing that, but that's not really stock. Maybe I should have clarified - 'stock' means 'unchanged' to me, so stock or unchanged suspension from the dealer is unacceptable because you have no idea if he set it to the middle of the range or not. You really shouldn't trust these things to the low man on the mechanic's totem pole.
And yes, the settings in the manual are right in the middle of the adjustment range.
lavudyar is offline
post #8 of 16 Old 08-22-2006, 11:33 PM
jstwkd1's Avatar
Ok not trying to be an ass here just learning myself. Arent the bikes set up for a 150 lbs rider? And isnt the determined by the spring rate. And the valving is for fine tuning for each individual?
jstwkd1 is offline
post #9 of 16 Old 08-22-2006, 11:39 PM
stock means factory setting to me and not from dealer.
the only setting in the middleis the front fork compression wich is at 7th click range 1 ~ 14.
nobody is offline
post #10 of 16 Old 08-23-2006, 09:28 AM
lavudyar's Avatar
Factory settings are non-existent. The bikes are assembled, started, disassembled, boxed and shipped. No one in Japan messes with the suspension settings before shipping. So while there is a recommendation in the manual for settings, who are you trusting to make sure they were done?
And don't forget the front rebound - 9th click of 18 (17 really, but everyone counts a bit differently). I didn't bother reading back to the rear settings.
Spring rate is set for a range of rider weights and styles of riding. Preload settings make the more specific adjustments for specific weights. The comp and rebound adjustments control movement rates.
lavudyar is offline
Help with Suspension settings bkbroiler Performance and Tech 10 08-04-2006 02:20 PM
06 Suspension Settings brian0128 Performance and Tech 42 07-28-2006 09:26 AM
Suspension settings again... Mustard Performance and Tech 8 06-17-2005 12:18 PM
Suspension settings that are right on!!! Older Guy Performance and Tech 3 10-15-2004 11:27 PM
Suspension Settings a The ZX-10R 2 04-06-2004 01:20 PM
