Help with Sprocket/chain Question - Kawasaki ZX-10R.net
post #1 of 4 Old 07-30-2008, 09:17 PM Thread Starter
Kelleyj3's Avatar
So I purchased a Driven 41t 525 sprocket for my 05'. The problem came when I put the wheel back on to the bike. I was told I wouldn't need a new chain. When I put the chain back onto the sprocket the axle is about a 1/4 to 1/3 of an inch off from the alignment needed for the axle. Can I buy a link and add it to my chain? Any Suggestions?
-Thanks,
Guy who wanted to keep stock chain.
Kelleyj3 is offline
post #2 of 4 Old 07-30-2008, 09:53 PM
javeci01's Avatar
Send a message via AIM to javeci01
I tried the same thing with a 16T up front and it was a no go. I think you need a new chain, not sure if adding a link is a good idea. Most people on the forums will tell you to get a new chain with a sprocket change anyways. Good luck.
04 Pearl Blazing Orange ZX-10R
javeci01 is offline
post #3 of 4 Old 07-31-2008, 12:40 AM
lenshead's Avatar
Yeah, an old chain will wear your new sprocket out in a jiffy, and vice versa, you should replace all 3 as a set.
Thou Shalt Respect Thy 10, And Revel In It's Power, For It Is Good, And Plentiful.
lenshead is offline
post #4 of 4 Old 07-31-2008, 01:05 AM Thread Starter
Kelleyj3's Avatar
Thanks for the info. Guess I will be hitting the local bike shops in the am.
Kelleyj3 is offline
chain sprocket set. 97on22s Vendors deals 1 07-18-2008 01:46 PM
Chain/Sprocket Set-up TRex Strip 2 02-16-2008 06:30 PM
FS: NEW RRP 44T 520 Chain Sprocket mjg68901 Parts, Gear and Accessories 2 01-25-2007 08:49 PM
Sprocket & 525 chain? KDW Performance and Tech 23 10-01-2005 05:13 PM
Chain/ sprocket question VegasZX10R Performance and Tech 50 08-13-2005 10:40 AM
