HELP: Rear wheel issues - Kawasaki ZX-10R.net
post #1 of 20 Old 06-15-2010, 05:30 PM Thread Starter
bluebeast10's Avatar
I recently did a tire change on my 08 zx10. I reinstalled my rear wheel and tightened the 18mm nut to 80 ft/lbs according to the repair manual and noticed the wheel would not spin without a lot of effort in neutral. Could this be a sign of bad bearings?
FYI I just had the wheels powder coated. I have 15k miles on the chain and front sprocket but the rear sprocket has less than 3k
bluebeast10 is offline
post #2 of 20 Old 06-15-2010, 05:37 PM
cardeea's Avatar
Check the spacers. You should be good from there.
On the Fast Orange One. Marvics Silverstone Gold Mag (lighter than Marshs), Full Akra Ti Hex, 14 Cals, PC3 with a bad ass map, Scotts, Pazzos, hell about 7k in aftermarket parts fast. So now you know I'm Floyd Money Mayweather fast!! Kanye taking the mic from Taylor Swift fast!! haha Just damn fast!!
cardeea is offline
post #3 of 20 Old 06-15-2010, 06:32 PM Thread Starter
What could be wrong with the spacers? Will I need new ones?
post #4 of 20 Old 06-15-2010, 07:04 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
Are you sure the chain isn't too tight? or try backing off the axle nut a half or full turn and see if that helps? best of luck though and your adjuster blocks are even on both sides of the swingarm right?
TMY10ER is offline
post #5 of 20 Old 06-15-2010, 07:11 PM Thread Starter
The chain is a little tight. I will check the adjuster blocks in the morning. Thanks
post #6 of 20 Old 06-15-2010, 09:15 PM
cardeea's Avatar
I think there are spacer issues. I tight chain will not hamper the rotation of the rear wheel (only a tight chain). Magic is right, spacers gets left off and people totally forget to add them to the re-install. Keep me posted.
cardeea is offline
post #7 of 20 Old 06-16-2010, 02:28 PM Thread Starter
both spacers are on the wheel
post #8 of 20 Old 06-16-2010, 02:34 PM
yea but there is one behind the sprocket and hub
speeddemon is offline
post #9 of 20 Old 06-16-2010, 02:42 PM
GEN II Driver
ripper's Avatar
my vote = spacers
MDCCLXXV
ripper is offline
post #10 of 20 Old 06-16-2010, 03:25 PM
themightymezzo's Avatar
If it's not spacers make sure your rear caliper is mounted correctly...doubt it but could be another possibility.
"You can't trust anyone, not even your own asshole; sometimes you think you're gonna fart and you sh*t."
themightymezzo is offline
Carrozzeria Wheel cush drive issues? miykl Performance and Tech 0 07-10-2009 09:40 AM
04 Front Wheel Removal Issues Twelch8668 Performance and Tech 1 04-29-2009 11:01 PM
TAILLIGHT/REAR FENDER ISSUES MAVRIK The ZX-10R 6 09-02-2004 02:43 PM
The known 3 wheel issues-anyone know the serial #'s steves87 The ZX-10R 11 08-14-2004 03:09 AM
