Help, rear tire slow leak - Kawasaki ZX-10R.net
post #1 of 26 Old 12-18-2009, 04:07 PM Thread Starter
ikaika's Avatar
I have a very slow leak in my rear tire. I was wondering, can it be patched or do I just need to replace it?
Custom FE/CA taillight/TechSpec/Driven D-Axis gas cap/Cox Racing/Champs frame-fork-swingarm sliders/Puig ZRacing/Titax/Woodcraft-Attack case covers/SME rear axle block sliders/Misc carbon fiber/ZG Latigo/HID's/M4 Street Slayer/BMC/XTre/EK 520 MVXZ/+4 Drive Sys/SpeedoHealer/HEL 'Stealth'-Motul RBF600-Galfer pads/KyleRacing damper/Rifleman's/Ivans b/o plates/Q3's/Motul 300v/Engine Ice/Shorai
http://www.maresohana.com/ktrsd
ikaika is offline
post #2 of 26 Old 12-18-2009, 04:18 PM
maser's Avatar
IDK, would you trust that plug at 150+ mph? or at a real aggressive lean angle? IMO it's worth the piece of mind to replace the tire. I personally wouldn't be able to get it out of my mind, knowing it's there.
Drive it like ya stole it --- keep the rubber side down !
maser is offline
post #3 of 26 Old 12-18-2009, 04:32 PM
Randy G's Avatar
I would replace it
Randy G is offline
post #4 of 26 Old 12-18-2009, 04:39 PM
canZX10r's Avatar
I wouldn't chance it! Replace it! Unless its a bad seal to the rim, then get it remounted.
canZX10r is offline
post #5 of 26 Old 12-18-2009, 04:58 PM Thread Starter
ikaika's Avatar
Yeah, I agree completely. Once I posted this, I should have just deleted it. Its not like a car that still has 3 other tires and which you have time to react. Loose the rear tire on a bike and just hope and pray. Im going to get it replaced.
ikaika is offline
post #6 of 26 Old 12-18-2009, 05:16 PM
JVT
Soap the stem first and see if thats where its leaking
JVT is offline
post #7 of 26 Old 12-18-2009, 05:25 PM
All show and all go 10r
JLG0987's Avatar
i have had my rear tire patched 1 inch from the edge of the tire and been fine. I DO NOT RECOMMEND THIS AT ALL!!!! its pretty damn risky. The only way I can agree with it now is if its in the center of the tire, but even still you shouldn't ride as hard. And if you fix it, inside patch ONLY!!! But in reality yes the tire should be replaced.
JLG0987 is offline
post #8 of 26 Old 12-18-2009, 05:38 PM
motomike's Avatar
i patch mine from the inside.i used plugs for years just fine til i learned to patch it myself.most people won't do it.if the patch does'nt work , then it's just a slow leak -again.
lead,follow or get out of the way !
motomike is offline
post #9 of 26 Old 12-18-2009, 05:44 PM
slow leak?
keep putting air in it if the treads good.
moneys tight nowadays, at least down here
craigntx is offline
post #10 of 26 Old 12-18-2009, 05:57 PM
motomike's Avatar
Originally Posted by craigntx View Post
slow leak?
what money ?
motomike is offline
Rear Rim, AlpineStar Jacket, Rear Tire FOR SALE currie954 Parts, Gear and Accessories 3 08-02-2009 09:58 PM
Rear tire has extremely slow leak russell Performance and Tech 15 04-08-2009 06:01 PM
Slow gas leak? yellow10r The ZX-10R 44 11-12-2007 10:53 PM
Tire Review: Dunlop N-Tec DOT rear race tire wsmc27 Track 4 08-09-2007 03:14 PM
Monting rear tire without tire machine? blackisfaster Performance and Tech 9 04-24-2007 01:28 PM
