HELP: R turn-signal problems - Kawasaki ZX-10R.net
post #1 of 3 Old 08-15-2008, 05:41 PM Thread Starter
pan
pan's Avatar
Images: 13
I installed aftermarket front turns(NOT LED).
Left side works perfectly, but the R don't.
I can get the R to work maybe every 7th
time I try, then they work fine. They continue
to blink until I hit the cancel button.
I replaced the signal relay with OEM, same!
Then went as far as doing the auto signal relay fix.
Same problem. The R turn-signal doesn't flash
but once every 7th try. Any suggestions guys??
2013 ZX10R(Non-ABS) Part Out
2003 ZX9R
2003 Yamaha Zuma 49cc(wife & kids)
1993 ZX7 (950 bigbore)
1992 ZX6D
pan is offline
post #2 of 3 Old 08-15-2008, 09:18 PM
FAF
Rent this space
Bad connection probably , its normally a bad crimp on the bullet connectors they supply.
FAF is offline
post #3 of 3 Old 08-20-2008, 09:49 PM Thread Starter
pan
pan's Avatar
Images: 13
Finally solved my problem. After replacing signal relay,
mounting an aftermarket signal relay, rechecking all 4
bulbs, and rechecking fuses, I bought a left-hand control
from Felix el gato. Included were the screws/wiring.
After plugging in like new control, signals worked
PERFECTLY!! If anyone needs a signal relay for at
the 04/05, I now own (3)............
2003 ZX9R
1992 ZX6D
pan is offline
'08 Turn signal mod available yet? bob agee The ZX-10R 45 09-03-2009 07:16 PM
Turn signal fix for 08. Dino Pictures and Videos 21 04-28-2008 10:06 PM
WTB rt rear turn signal 06-07 & lft front turn signal zero lash Wanted: Buy or Trade 2 03-05-2008 08:33 AM
rear turn signal problems teamgreen Performance and Tech 9 01-29-2008 04:32 PM
Turn signal mod? pieter3d The ZX-10R 27 12-03-2007 11:08 AM
